C Prog Q: Find Dist btwn 2 Sets of Points Without math.h
The discussion revolves around finding the distance between two sets of points in a C program without using the math.h header file. Participants explore various methods for calculating square roots, which is essential for determining the distance, while considering the constraints of a beginner programming course.
  • Homework-related
  • One participant expresses difficulty in calculating the square root without the math library and suggests writing a separate function for distance calculation.
  • Another participant proposes several methods, including brute force, binary search, and numerical approximation, noting that the squared difference might suffice.
  • A suggestion is made to use the Newton-Raphson method for root finding, described as quick and simple.
  • One participant inquires about the compiler being used, suggesting the possibility of embedding assembly code for square root calculation.
  • Another participant cautions against using assembly, arguing that the assignment is meant to teach C programming fundamentals rather than low-level architecture.
  • A participant reveals their beginner status in programming and requests simpler solutions.
  • Further elaboration on the Newton-Raphson method is provided, detailing the iterative process for approximating square roots and suggesting a simple implementation in C.
  • Another participant reiterates the use of Newton's method and provides a non-recursive implementation for square root calculation, while also warning against the potential pitfalls of recursive functions.
  • A link to an external resource on calculating square roots is shared, although it is noted that it may be beyond the course's scope.
Participants present multiple competing views on how to approach the problem, with no consensus on a single method for calculating the square root or the best way to implement the distance calculation.
Some methods discussed may depend on the participant's familiarity with numerical methods and programming concepts, and there are unresolved considerations regarding the appropriateness of certain techniques for a beginner course.
mathrocks
I have a question about a C program that I'm trying to write. I need to write a program that finds the distance between two sets of points (x1, y1) and (x2, y2) without using the math.h header file. I'm currently doing functions in my class, so I suppose I have to write a separate function that calculates the distance. But what I'm having trouble with is how to take the square root without using the math library.
Computer science news on Phys.org
You could brute force through steps of a fixed size. You could do a binary search. You could remember back to your math classes and use a numerical approximation. You could look up a numerical approximation in a reference book. Depending on your task, the squared difference might even be enough, meaning you don't have to take the square root!
Use the Newton-Raphson root finding method. It's quick and simple.
- Warren
Which compiler do you use? You could easily embed 1 line of asm (which is essentially what math.h does).
I'm asking about which compiler because the syntax of inline asm varies from compiler to compiler. I'm sure you'll find it on google though.
Yes, you could certainly talk to the floating-point unit directly via asm, but I don't really think that's what the teacher intends for him to do. I believe this assignment is designed to teach C, not x86 architecture.
- Warren
Wow, all great responses but I guess I didn't tell you guys my level of programming. This is my first programming class, it's a beginners course and the most we've done is recursive functions and this problem was in that section. Any way to do it really simple?
I believe my answer is quite simple to implement. The Newton-Raphson method is an iterative way to numerically find a zero of a function.
If you're looking for the square root of some number m, it should be obvious that you're looking for the zero of the function [itex]f(x) = x^2 - m[/itex].
The first derivative of this function is [itex]f^\prime (x) = 2x[/itex].
The Newton-Raphson method begins with a guess. Any guess will do, but a bad guess will require more iterations to converge on the final answer. To apply the Newton-Raphson method, plug your guess into the relation
[tex]x_{n+1} = \frac{x_n^2 - m}{2 x_n}[/tex]
Where [itex]x_n[/itex] is the current value, and [itex]x_{n+1}[/itex] is the next value. Keep doing this iteration, plugging that [itex]x_{n+1}[/itex] back in as [itex]x_n[/itex]. You'll see that after five or ten iterations, you've calculated a very very good approximation of the square root.
You could also keep iterating until the value only changes by say 0.0001 or less from one iteration to the next, guaranteeing at least that much precision.
You should be able to write this code in something like three or four lines of C code. If you need additional help, please let me know.
- Warren
Use Newtons method as already stated.
Here, this process should help: http://www.merriampark.com/bigsqrt.htm
You can do this as a recursive function, but that's not required.
Code:
//the non-recursive way to do it.
//doing this recursively is just as easy, good luck.
double squareRoot(double numToRoot, double guess)
	while(true) //sets up an infinite loop
		//function to approximate the root
		double n=((numToRoot/guess) + guess)/2;
		if (n==guess) //breaks out of loop when root is found
		break;
		guess=n; //reassignes guess for next iteration of loop
	return guess; //returns the root to the function call.
Just as an aside, though you're learning about recursive functions, you should also avoid them like the plague unless absolutely necessary. Recursive functions can become unweildy very quickly.
Well, good luck.
[edit] Also, the above code probably won't work if you cut and paste it. If you're learning C see if you can spot the 'error' in my implementation.
11K
35K
