Equilibrium temperature of heat exchanger
The discussion centers on the equilibrium temperature of water in a closed loop system featuring a heater and a fan-cooled finned heat exchanger. It is established that while the system can reach an equilibrium state, it does not necessarily reach a fixed equilibrium temperature. The heater's power, cooler's efficiency, flow rate, volume of water, and initial temperature are critical parameters influencing the system's behavior. The temperature rise of the water is constant if the specific heat remains unchanged and the heat flux from the heater is constant, leading to a dynamic temperature change rather than a static equilibrium.
  • Understanding of heat exchanger principles
  • Knowledge of specific heat capacity
  • Familiarity with thermal dynamics in closed loop systems
  • Basic equations governing heat transfer
  • Research the equations for heat transfer in heat exchangers
  • Explore the concept of thermal equilibrium in fluid systems
  • Study the impact of flow rate on heat exchanger efficiency
  • Learn about specific heat capacity variations with temperature
Engineers, thermal system designers, and anyone involved in optimizing heat exchanger performance will benefit from this discussion.
Escheresh
In a closed loop with a heater and a fan cooled finned heat exchanger where water flows between the two, is it right to assume that the water will reach an equilibrium temperature?
If so, is there an equation that can get the equilibrium temperature?
The power of the heater and cooler, the flow rate, volume of water and initial temperature are known.
I don't think the system will reach an equilibrium temperature, but it can reach an equilibrium state.
If the water doesn't boil, we can assume it has a constant specific heat, and I don't know what your specifics are, but it might also be safe to assume that the heat flux from the heater is a constant. If this is true, then the temperature rise of the water between the inlet and outlet of the heater is a constant.
So, if everything is at ambient temperature before you "switch it on," the water will start to flow and the water leaving the heater will be at some elevated temperature (ambient temperature + some constant temperature rise). The efficiency of the heat exchanger depends on the difference in temperature between ambient air and the water, so it might not (probably will not) be cooled back to ambient temperature. After several passes, the water might be hot enough that the temperature drop at the heat exchanger is equal to the temperature rise at the heater, so now your system is at its equilibrium state. But the water is still changing temperature.
-Kerry
  • · Replies 34 ·
  • · Replies 21 ·
