| Thread Closed |
most popular board layout program |
Share Thread | Thread Tools |
| Jul7-09, 06:56 PM | #1 |
my boss wants me to start learning how to layout a board. i suggested that i should start learning orcad, but he said that he thinks that orcad is "a little old." he wants to pick a new layout program, one which is popular. what do u guys use?
| Jul7-09, 09:22 PM | #2 |
www.cadsoftusa.com
- Try the free version. Unfortunately it no longer comes with an autorouter. But it is a way to get your feet wet. |
| Jul7-09, 09:40 PM | #3 |
Recognitions:
Eagle also offers a nonprofit version that includes the autorouter and other enhanced capabilities for $US125.
If that's overbudget, try the open source Kicad. |
| Jul8-09, 12:28 AM | #4 |
Mentor
most popular board layout programDo you need to pick a cheap package? What is the complexity of the boards you will be laying out? How important is a good autorouter to your work? If you want something free/cheap/limited, then Eagle may work. If you are going to do professional multi-layer boards, especially complex ones, then OrCAD or PCAD are common packages (but not cheap). |
| Jul8-09, 05:41 AM | #5 |
lol i know what ur saying, especially since he currently uses protel |
| Jul8-09, 06:24 AM | #6 |
Recognitions:
Oh, well, if your budget is unlimited, the EEs where I work use a high-end package called PADS. It is NOT cheap. It's probably overkill for your simple boards.
| Jul8-09, 06:45 AM | #7 |
oh yes, we have some people who have done some stuff for us in pads. whats the difference between pads and orcad?
| Jul8-09, 07:19 AM | #8 |
ive just heard there is a new version of protel called altium, is there alot of support for that?
| Jul8-09, 11:56 AM | #9 |
Use the same program your boss is using.
Then when you require help with the program, there is someone there that can help you. |
| Jul8-09, 12:21 PM | #10 |
One place I used to work had Pads. Sometime later we bought Pspice without Orcad. Then when we wanted to transfer a design from Pspice to Pads, we had to do it manually. Yes, Orcad is old. I used it when it was still a DOS program but I'm sure it's updated and it allows transferring designs directly from Pspice if that's what you want to do.
| Jul8-09, 12:34 PM | #11 |
I'm currently learning Eagle from CadSoft. So far it seems ok but IMO has rather weak tutorials and help files so there's a bit of a learning curve associated with it. I really wish you could import Pspice models/schematics into it.
| Jul8-09, 06:33 PM | #12 |
| Jul8-09, 06:48 PM | #13 |
Recognitions:
Always wondered what happened to Protel it was a really nice step up from cadstar 10years ago.
| Jul10-09, 07:04 AM | #14 |
I use Pads for everything from simple, 2-layer, ~ DC test boards to complex, high speed, high layer count boards. I'm pretty happy with it and Mentor is making active updates to improve it and add features (recently added 3 D viewer, IPC netlist output, and increased ease of use). You can download a version that is limited to a certain number of parts and nets for free if you want to try before you buy.
I've never used Altium but when I checked it out at a trade show it looked like a good tool and had some features that Pads didn't at the time. I had looked at OrCad layout a few years back and stayed away because it didn't seem to have the industry support that Pads had although the OrCad shematic tool was often used with Pads layout. I know people that use cheap/free layout packages for simple boards and are happy with them but if you have the budget you might as well learn a layout tool that you can grow with and interface to other tools (signal integrity, thermal analysis, etc) if needed. There are part footprints/decals readily available for PADS for most parts including connectors which can save a lot of time and prevent errors from manually making them. Mentor also provides free translators so you can translate from some other formats to theirs. Pads has a pretty good install base so when we're overloaded it is fairly easy to find someone that can do the layout on a contract basis. Also consider that learning Pads, Altium or some other commercial tool is a good thing resume wise. If your employer will pay you to learn them you should take advantage of that. Bottom line, I don't think you'll be disappointed with Pads but if you have time to do an eval, Altium may be worth a look as well. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: most popular board layout program
| Layout verification | Electrical Engineering | 2 | ||
| PCB Layout Help | Electrical Engineering | 10 | ||
| New layout? | General Discussion | 2 | ||
| PF has a new layout? | Forum Feedback & Announcements | 5 | ||
