Solve Small Oscillations in 1 Spring System
The discussion revolves around a system of two masses connected by springs, focusing on the analysis of small oscillations and the determination of particular solutions given initial conditions. The subject area includes concepts from classical mechanics, specifically normal modes and eigenvalue problems in dynamical systems.
  • The original poster attempts to derive a particular solution for the system when one mass is given an initial speed, raising concerns about the number of unknowns in relation to the initial conditions provided. Some participants suggest interpreting the initial conditions in terms of the eigenbasis, while others question the differences in their approaches to solving the eigenvalue problem.
The discussion is ongoing, with participants exploring different interpretations of the problem and seeking clarification on notation and methods. There is a collaborative effort to verify calculations and ensure understanding of the transformation to the eigenbasis.
Participants note the assumption of default initial conditions being zero for displacement and velocity, except for the specified initial speed of one mass. There is a mention of the complexity introduced by the number of unknowns relative to the initial conditions.
CNX
A horizontal arrangement with 1 spring in between the two masses, 1 spring connecting each mass to opposite fixed points:
k 3m k 8m k
I solved the eigenvalue/eigenvector problem for the dynamical matrix D where [tex]V = 1/2 D_{ij} w_i w_j[/tex] and the w's are mass-weighed-coords. So I have the frequencies for the normal modes.
[tex](D-I\omega)\cdot \vec{b} = 0[/tex]
How do I get the particular solution for when a single mass is given a initial speed 'u'? Without getting the amplitude vectors for each normal mode I don't see how to get the particular solution as there are too many unknowns?
[tex]x_i (t) = \sum_{j} c_{i}^{(j)} \cos (\omega_j t + \delta_j)[/tex]
i.e 6 unknowns and and 4 IC's x1(0)=0, x2(0)=0, v1(0)=u, v2(0)=0
I would assume that the default initial condition is implied as zero displacement and zero velocity for both masses. So, if they tell you that one of the masses is given a kick of velocity u, then I would assume that the initial conditions are otherwise zero. Then, use your transformation to interpret this initial condition in terms of the eigenbasis.
I'm not sure how to go about doing that...
How is what I did different than solving [tex](V-\omega^2 T)\cdot \vec{a}=0[/tex] for eigenvalues [itex]\omega_1,\omega_2[/itex]? i.e. where T is constructed form the KE and V matrix is constructed from the PE, and is similar to my dynamical matrix D above.
I don't know what your notation means, exactly, but it looks OK. It would help if you would tell me what eigenfrequencies you got and what is your transformation matrix to the eigenbasis so that I can see if you're on the right track (and to double check that I didn't make a mistake either).
