General relativity and Newton's laws
The discussion revolves around the gravitational force acting on a particle of mass m on the surface of a large sphere, specifically considering whether Newtonian mechanics suffices or if general relativity is necessary due to the mass density involved. The scope includes theoretical implications of both Newton's laws and general relativity, as well as the nature of gravitational forces in extreme conditions.
  • Some participants question whether the gravitational force can be accurately described using the Newtonian formula or if general relativity must be applied due to the sphere's mass density.
  • A participant corrects an earlier post regarding the formula for gravitational force, noting that the radius should be squared rather than square-rooted, and discusses the role of normal force and inertial forces in general relativity.
  • Another participant mentions that a mass cannot be held still over a black hole's event horizon, suggesting that any mass on the sphere would need to be in motion.
  • There is a discussion about the existence of gravitons and whether they would relate to the "felt" force or the four-velocity force in general relativity.
  • One participant asserts that mass is invariant even in a gravitational field and critiques the use of certain expressions that are not representative of modern general relativity.
Participants express differing views on the applicability of Newtonian mechanics versus general relativity in this context. There is no consensus on whether the gravitational force should be treated using classical or relativistic approaches, and multiple competing perspectives are presented.
Some statements rely on specific assumptions about the nature of gravitational fields and the definitions of mass in different contexts. The discussion includes unresolved mathematical expressions and varying interpretations of physical concepts.
kurious
Is the gravitational force acting on a particle of mass m, on the
surface of a sphere of radius 10^24 metres and with a mass of
10^52 kg given by G x10^52 m / (10^24 ) ^ 1/2 - the Newtonian value - or is the mass density high enough for general relativity to be required to get a
sensible result?
sensible result?
r is squared, not square rooted. In general relativity The law of motion can be written [tex]F^\lambda = m(\frac{dU^\lambda }{d\tau }) + m\Gamma ^{\lambda }_{\mu }_{\nu }U^{\mu }U^{\nu }[/tex].
The real force on your test mass is the normal force holding it up and is expressed as the four vector on the left hand side of the equation. The last expression on the right can be called the gravitational force, but is only an inertial force which are sometimes called fictitious forces. What I think you really intend to compare is the prediction from Newtonian mechanics for the weight measured on a scale Vs the prediction for the measurement from general relativity. What the scale really reads is the reaction force on it associated to the real normal force up on the test mass. The readout for the general relativisitc prediction would be given from equation 10.2.1 at
http://www.geocities.com/zcphysicsms/chap10.htm#BM10_2
[tex]F'_{felt} = \frac{GMm/r^{2}}{\sqrt{1 - \frac{2GM}{rc^2}}}[/tex]
Apparently, a mass can't be held still over the event horizon of a black hole, so the mass I was talking about would have to be in motion on the surface of the sphere.
If gravitons exist would they have to account for the "felt" force or F lambda?
Under. Over it can be held still just fine. Under the event horizon of a Shwarzschild hole all things are constrained to fall toward the physical singularity. Whatever matter you have producing the normal force up on the test mass is what is responsible for that force. General relativity is not a quantum theory and as such has no gravitons. Those are proposed by particle exchange theories.
sensible result?
The gravitational field alters the mass of the particle. If the proper mass of the particle is m0, and the particle is not moving, then the mass of the particle is
[tex]m = m_{0}\frac{dt}{d\tau} = \frac{ m_{0} }{ \sqrt{1 + 2\Phi/c^2}}[/tex]
where
[tex]\Phi = -\frac{GM}{r}[/tex]
The gravitational force G is then given by
[tex]G = \frac{GMm}{r^{2}}[/tex]
Pete
Mass is invariant. Even in the presence of a gravitational field, Riemannian spacetime curvature, the quantity
[tex]m = \frac{\sqrt{|g_{\mu }_{\nu }p^{\mu }p^{\nu }|}}{c}[/tex]
which is defined as the mass of a free particle for modern general relativity does not depend on frame, speed, position, etc. Pmb's expression is not generally covariant-
http://groups.google.com/groups?q=+...=off&selm=34EE0B44.399A3FA1@lucent.com&rnum=7
and as such is not representative of modern general relativity. On a more basic note, it is bad to use the same case of the same letter to represent two different things in the same equation as in pmb's
"[tex]G = \frac{GMm}{r^2}[/tex]"
  • · Replies 16 ·
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 38 ·
