Thread Closed
confused on this dielectric capacitance problem
Share Thread Thread Tools
Jun24-04, 02:12 PM   #1
The electric field between the plates of a paper-separated (K=3.75) capacitor is 9.41E4 V/m. The plates are 1.75mm apart and the charge on each plate is 0.775E-6C. Determine the capacitance of the capacitor and the area of each plate?
I got the voltage by V=Ed. and that came out to 164.675
Where do i go from there because in order to get capacitance you need to know area, and finding the area of each plate is also a question in the problem. I thought about using C=Q/V, but that doesn't apply for dielectrics. Can someone helpme out?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jun24-04, 02:58 PM   #2
I think you should be able to use the fact that [itex]E = \frac{Q}{\epsilon_0A}[/itex]. This gives you an equation for the area which you can use to determine the capacitance.
Jun24-04, 03:28 PM   #3
I tried that and that did not work out either, do you have anymore suggestions?
Jun24-04, 06:54 PM   #4
Mentor
Quote by supermenscher
Who says that C = Q/V doesn't apply for dielectrics? It's the definition of capacitance.
Thread Closed
Thread Tools
Similar Threads for: confused on this dielectric capacitance problem
Thread Forum Replies
Dielectric constant, metals, frequency... a bit confused Classical Physics 11
capacitance of parallet plate with dielectric spheres in between Introductory Physics Homework 2
Capacitance Dielectric Problem Introductory Physics Homework 8
Capacitance W/ Dielectric Problem Introductory Physics Homework 6
[SOLVED] Cyber forum of Dielectric Phenomena or of Dielectric and Electrical Material General Physics 0
