| Thread Closed |
Linear Algebra (Linearly Independent vs. Linearly Dependent) |
Share Thread | Thread Tools |
| Jul11-09, 08:52 AM | #1 |
If S = {v1, v2, v3} where v1, v2 and v3 are in [itex]\mathbb{R}^2[/itex], then the vectors v1, v2 and v3 are linearly independent. 2. Relevant equations None 3. The attempt at a solution I thought the answer was true, but I know the correct answer is false and I'm not sure why. Here was my reasoning for true: If this implies that these three vectors span [itex]\mathbb{R}^3[/itex], then they must be linearly independent. If they weren't, then they would only span [itex]\mathbb{R}^2[/itex] or [itex]\mathbb{R}^3[/itex] space. Moderation Note: Please do not use latex unnecessarily. Latex requires a lot of resources to generate and large latex images, such as blocks of text, can scroll off the screen. It is much better to simply use standard text (with bb code) for text and latex exclusively for mathematical symbols. Note that you can general inline latex using the [ itex ] tags. Hootenanny |
| Jul11-09, 08:58 AM | #2 |
So is the problem asking you whether or not this statement is true? Is there any other information given regarding what S is?
| Jul11-09, 09:00 AM | #3 |
Sorry. Yes, this is a true/false question. S is a set of vectors [tex]v_1, v_2 \text{ and } v_3 \text{ in }\mathbb{R}^3 \text{ space}[/tex]. That's all that is given.
| Jul11-09, 09:19 AM | #4 |
Okay. Cool. So if you think it is false, then you need to try and come up with a counterexample. That is, you need to find three vectors in R3 such that the three vectors are not linearly independent, i.e. they are linearly dependent.
I think what you have as a solution to it being true is wrong because it isn't given that S spans R3. If it was given, then what you have would be correct, but that isn't given information. |
| Jul11-09, 09:23 AM | #5 |
Oh, I see. So the keyword is span, I suppose. I guess you can still imagine a 3-D space with these vectors even if the vectors don't span that space. OK, that makes sense.
Thanks! I posted two other T/F questions - do you think you could take a look? |
| Jul11-09, 09:27 AM | #6 |
Can you find three distinct vectors in R^3 that are linearly dependent?
| Jul11-09, 11:55 AM | #7 |
What is a better way to think about it? |
| Jul11-09, 12:12 PM | #8 |
One of the things you should have learned already is that, in a vector space of dimension n, there cannot be a set of fewer than n vectors that spans the space nor can there be a set of more than n vectors that are independent.
| Jul11-09, 12:25 PM | #9 |
| Jul11-09, 02:09 PM | #10 |
| Jul11-09, 04:28 PM | #11 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Linear Algebra (Linearly Independent vs. Linearly Dependent)
| Linearly dependent | Calculus & Beyond Homework | 4 | ||
| Linear Algerba - Finding linearly independent vectors | Linear & Abstract Algebra | 5 | ||
| Linear algebra and linearly independence | Calculus & Beyond Homework | 4 | ||
| Linearly dependent or independent functions? | Calculus & Beyond Homework | 6 | ||
| LINEAR ALGEBRA: 3 vecotrs in R^4 (with 6 variables) -- Are they linearly independent? | Calculus & Beyond Homework | 3 | ||
