Equivalence principle + light speed postulate =
The discussion revolves around the relationship between Einstein's equivalence principle and the constancy of the speed of light, particularly in the context of gravitational propagation. Participants explore whether these concepts imply a constant speed of gravitational propagation in a vacuum, examining both theoretical implications and mathematical formulations.
  • Some participants suggest that combining the equivalence of gravitational and non-gravitational acceleration with the constancy of light speed should imply a constant speed of gravitational propagation.
  • Others argue that it is unnecessary to invoke the constant velocity of light or relativity to derive gravitational acceleration, relying instead on Newton's law of gravitation and the equality of inertial and gravitational mass.
  • A participant questions how the previous claims demonstrate that the velocity of gravitational propagation is constant.
  • Some participants propose that any constant, such as gravitational acceleration (g), can be used in the mathematical framework, suggesting that the conclusions remain consistent regardless of the constant chosen.
  • There is a challenge regarding the absence of a defined constant of velocity in Hall's equations, indicating a need for clarification on this point.
  • One participant hypothesizes that the combination of the equivalence principle and light speed constancy should yield a constant gravitational propagation speed, reiterating the need for a clear definition of propagation speed.
Participants express differing views on the necessity of light speed in deriving gravitational propagation speed, leading to an unresolved debate regarding the implications of the equivalence principle and the constancy of light speed.
Participants highlight the dependence on definitions of constants and the mathematical relationships involved, with some unresolved questions about the propagation speed of gravity and its representation in existing equations.
Loren Booda
It seems to me that Einstein's equivalence of gravitational acceleration and non-gravitational acceleration, when combined with his constancy of light speed in vacuuo, should yield a constancy of gravitational speed in vacuuo.
It's not necessary to appeal to the constant velocity of light or relativity in general.
F= G(gravitational mass A)(gravitational mass B)/r2
(inertial mass A)(acceleration of A)= F so as long as inertial mass= gravitational mass:
acceleration of a= G(gravitational mass B)/r2, a constant.
How does this show that the velocity of gravitational propagation is constant?
pick a constant, any constant. if you don't like c, take g. the math still works out to the same conclusion.
So where is the constant of velocity in Hall's equations?
All you have proven is that the acceleration due to gravity is dependent only upon the object causing the accelerationa and not the accelerated object. Loren's question has to do with the propagation speed of gravity. Perhaps Loren could explain more clearly what is meant by this.
The speed of light propagation is c. Propagation speed in general may be finite or infinite. Simply put, propagation speed is distance per the time that particle action takes to travel over that distance.
Here I hypothesize that
Einstein's equivalence of gravitational acceleration and non-gravitational [inertial] acceleration, when combined with his constancy of light [propagation] speed in vacuuo, should yield a constancy of gravitational [propagation] speed in vacuuo.
  • · Replies 78 ·
  • · Replies 76 ·
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 44 ·
