Electron Phasepositive and negative?
  • Context: Undergrad
  • Thread starter Thread starter rabbitweed
    Electron Negative
The discussion centers on the concept of phase in molecular orbital (MO) theory, specifically regarding p orbitals in chemistry. The user clarifies that phase refers to the complex phase of the wave function at a given point, rather than merely the orientation along the x, y, z axes or the magnetic moment. The lobes of the p orbitals represent regions of probability for finding electrons, and a 180-degree rotation between lobes results in a sign change, illustrating the concept of phase shifts similar to sine and cosine functions.
  • Understanding of molecular orbital theory
  • Familiarity with p orbital shapes and electron probability distributions
  • Basic knowledge of complex numbers in quantum mechanics
  • Concept of phase shifts in trigonometric functions
  • Study the mathematical representation of wave functions in quantum mechanics
  • Explore the significance of phase in molecular orbital interactions
  • Learn about the implications of phase in chemical bonding and reactivity
  • Investigate the role of symmetry in molecular orbitals
Chemistry students, educators, and anyone interested in deepening their understanding of molecular orbital theory and the behavior of electrons in atoms.
rabbitweed
EDIT: This may be better in the Chemistry forum, I'm really not sure.
I'm just doing some basic qualitative MO theory for my first year chemistry class, and i am becoming quite confused.
My text says shows your typical 'dumbbell' model of a p orbital, each a different colour, and states "The two lobes of the p orbitals are of opposite phase."...without actually explaining what phase is.
Is phase just another name for it's orientation along an x y z axis, or does it have to do with the magnetic moment?
In the "dumbbell" model of the p orbital, the size and shape of lobe is related to the probability of finding the electron at that angular location. It's a bit more complicated, because, strictly speaking, the value at any given point on the surface is actually a complex number, where the phase refers to the complex phase at that point. The dumbell surface actually represents the angular part of the wave function describing the electron in that orbital, which is a complex number in general.
If you start at some point on one lobe, and rotate around by 180 degrees such that you're on the other lobe, this new point will have opposite sign from the point you started at.
If you're familiar with the idea of phase shifts when talking about sine and cosine functions, then you can see how a shift of 180 degrees causes the point to flip sign. It's kinda like that in this case.
ah, so it's purely a spatial thing. Thanks, I think I get it now.
  • · Replies 36 ·
  • · Replies 36 ·
10K
