AC Power and Combining Volt/Current
AC power allows for the combination of multiple 220V lines to effectively supply higher voltages, such as 660V, by utilizing phase differences among the wires. The discussion highlights that while three 220V wires can be used to power an appliance requiring 660V, the return line can be at 0 volts, minimizing current flow through it. This is due to the phase differences in a three-phase system, where the voltage difference between phases can reach about 440V, not exceeding the individual wire limits. The conversation also touches on the use of transformers to adjust voltage levels and the importance of understanding star and delta configurations in three-phase systems. Overall, the key takeaway is the efficiency of AC systems in managing voltage and current through phase manipulation.
elink24
One of the reasons we use AC power instead of DC is that with AC, we can use a single wire with a maximum voltage of 220V to return 660V. This is done by combining 3 lines of 220V into a single one. How can this be done without exceeding the wire's max voltage of 220V?
My teacher also added this to clarify, "Ha, I realized that I was thinking in European terms, where they use 220V. Anyway, suppose I have an appliance (like an AC) that needs 660V to run. I can run this by connecting 3 220V wires to it, just like you'd use 3 4V batteries to run something that needs 12V. Suppose each wire can hold a maximum of 10A, and that's what's going through the 3 incoming wires. Now, there is a trick I can use to only need a single return wire (as opposed to the 3 incoming wires), even though it seems it would have to carry 30A (which is more than it can hold). What is the trick?"
My only thought was that one could use a transformer to take (incoming) 660V in 3 wires into 1 wire of 220V. But then would I have 3 turns on one end and one on the other?
\DeltaV2 = N2/N1 * \DeltaV1
220V = x/3 * 660V
But then x=1 turn, and what current or voltage would it carry?
elink24 said:
1One of the reasons we use AC power instead of DC is that with AC, we can use a single wire with a maximum voltage of 220V to return 660V.
Not really - the reason for using AC is that it is easier to step up/down voltages.
No, the largest voltage difference between two 230V phases is 415v - I don't know where you get 660V from
The trick is that the return line is at 0 volts, power flows back and forth through the live phases - in an ideal case there is no current in the return line.
Think of it has 2 batteries back-to-back both powering separate 1.5V lamps, you can connect the point between the two batteries to ground
The first and second paragraph look like 2 different questions. Which question are you answering? For example, first paragraph the wire has max voltage of 220V, but in second paragraph this new wire only has max current of 10A.
Edit, nevermind, hah.
Yes, I know it's confusing. The second part was an email from my teacher where he was trying to clarify the question for a student.
I got 660V because there is three wires each carrying 220V towards the appliance. So the return line would have no current, or no voltage? I guess I don't understand how a closed circuit could have part of the circuit at 0 volts.
Can anyone else help me with this problem?
Don't you hate Lex?
in case of a 3 wire system, the difference between the wire and ground is 220V. But the three wires have a phase difference of 60 degrees each. Hence, when u calculate the rms voltage between the wires, the difference is about 440V only. Here, no wires are joined to make one wire. There are 2 systems of connecting 3-phase supplies -Star and Delta. These links might help you better than me. http://eece.ksu.edu/~starret/581/3phase.html
http://www.animations.physics.unsw.edu.au/jw/power.html
17K
