VIsualizing the 4th Spacial Demension
  • Context: Undergrad
  • Thread starter Thread starter Zantra
The discussion revolves around the challenges of visualizing the fourth spatial dimension, particularly in relation to concepts like tesseracts and hypercubes. Participants explore various analogies and methods for understanding this abstract concept, touching on both theoretical and conceptual aspects.
  • One participant expresses difficulty in visualizing the fourth spatial dimension and seeks better explanations or frames of reference.
  • Another participant argues that it is logically impossible to visualize a 4D object, as perception is limited to 2D slices of 3D objects.
  • Some participants suggest that while we perceive 3D objects, our understanding is still constrained to 2D representations, which complicates the leap to 4D visualization.
  • There is a suggestion that visualizing a hypercube requires a different cognitive ability, and that true visualization of 4D is impossible for humans.
  • Some propose that holographic or computer modeling could aid in visualizing the fourth dimension, though it may still seem odd.
  • One participant mentions that attempts have been made to visualize 4D objects, albeit rudimentarily, and questions how one transitions from 3D perception to 4D visualization.
  • Another participant states that while a true representation of the fourth dimension is unattainable, it can be viewed similarly to how 3D objects are represented on screens.
  • There is a claim that to visualize a higher dimension, one must sacrifice a lower dimension, which requires imaginative effort.
  • A participant elaborates on the limitations of perception, explaining how light and geometry affect our understanding of dimensions.
  • There is a question regarding the nature of the fourth spatial dimension, with references to theories like M-theory and the idea of curled-up dimensions.
Participants generally agree on the inherent difficulties of visualizing the fourth spatial dimension, but multiple competing views remain regarding the methods and possibilities of achieving such visualization. The discussion does not reach a consensus on how to effectively conceptualize or represent the fourth dimension.
Participants express various assumptions about cognitive limitations and the nature of perception, which remain unresolved. The discussion includes references to theoretical frameworks like M-theory without definitive conclusions.
Zantra
Hello people. I'm relatively knew here. I've posted already but consider this a formal introduction. That being said...
I'm having quite a hard time visualizing a 4th spatial demension. I mean I've seen a model of a tesseract, but still the concept escapes me. It's basically as if our 3 dimensions were turned on their sides as a piece of paper, and a 4th demensional object was passed through it. I guess I need a better frame of reference. Anyone know of a better way to eplain this or visualize it?
Or do I already have the concept down and I'm overthinking this?
It's logically impossible to visually imagine a 4D object. That's because we can only ever see any given volume of space one 2D slice at a time.
If it helps, try to visual with analogies using lower dimensions.
So you're saying that even though we can percieve a 3 demensional object we're still seeing it in 2 demensions? could not our mind then make the leap to visualize 4 dimensions in much the same way? So then if a 4th demensional object were to protrude into 3 demensional space much like the ball through the piece of paper, would it then seem to come "out of thin air"?
Indeed that is the case. To visualize a 4d cube, a hypercube as it is known would require totally different brains. We see 2D cross-sections, including 2D cross-sections of a wireframe hypercube which is easily found online. To visualize it properly we would need to be able to see 3D cross-sections, meaning a full 3d object in one view without rotation. Impossible it is for us to visualize that making it impossible to visualize a hypercube.
It could be done holographically or on a computer 3 modeler, though it would seem odd.. At least I think...
but computers are programed by people, who are unable to visualize a fourth spatial demension.
Actually I think it's already been done on a rudimentary level. If it can be concieved, it can be visualize, though maybe not easily Not saying it was a true representation, but I do know an attempt was made. I'll have to look for it
If you've gone through your whole life looking at the world in 2D and visualizing 3D, then how do you go about looking at the world in 3D and visualizing 4D? The brain doesn't work that way. We have limits to our perception and it's not exactly easy to 'trick' our brains into thinking any differently.
There is indeed no way to see a true and accurate representation of the 4th demension, however you could view it much as you would view a 3D demensional object on a screen.
i don't think it's possible Zantra. the best we can do is to sacrifice a lower deminsion (say, z) and then have in its place a represtantion of the higher dimension. you still have to stretch your imagination a bit, but that's the way it's done.
No we aren't. We live in a 3D world, but can only see it one 2D slice at a time. Light travels off a surface to your eye, and the geometric pattern that strikes your retina is 2D. Thus, the image in your brain is going to be 2D as well. That is part of the reason why you can't see through objects. If light was not limited to 3 dimensions and could travel in a straight line towards you eyes off every sigle point on a 3D volume, you could then at least imagine it. But then, you would have to be a 4 dimensional being yourself, with a retina with a 3D volume for recording data.
It helps to use lower dimensions for analogy. Imagine a 2D stick person, and observe that light in a 2D universe can only move along the x,y axis. Now imagine a 2D persons retina. Since it is 2D, the "surface" in this case is really a 1D edge, and the geometric pattern from light striking it will be 1D as well. So this poor 2D person will only be able to view his 2D universe one 1D slice at a time.
In order for him to see the full 2D, two things must happen. First, he must become 3D, so that his retina goes from being an edge to a surface. 2nd, light must be able to move along the x,y,z axis, so that it might strike all points of the surface, giving a 2D geometric pattern. That is a similar analogy for a 3D universe. We would need to be 4D people living in a 4D universe in order to imagine a 4D object, in the same way that depth perception works from a 2D image.
by the way, I'm familiar with the four dimensions (x,y,x,t), but what is the fourth spatial demension. is it one of the ones that they thought would be curled up very small in another deminsion?
Going by the M-theory, yes. Or you could just think of it as the 5th demension, or whatnot.
10K
