Mixture Ratio for oxygen/propane in a rocket engine?
The optimal mixture ratio for oxygen/propane in a rocket engine is established at 4.5 to 1, based on various propulsion literature. The discussion highlights conflicting information regarding the air/fuel mixture ratios, particularly noting that the fuel air ratio for a jet engine is 15 to 1. A key point of contention is the assumption that the oxygen mixture ratio can be adjusted based on the percentage of oxygen in the air, which is actually 21%, not 30%. This leads to a recalculated air/propane mixture ratio of approximately 21.4 to 1.
  • Understanding of rocket propulsion principles
  • Familiarity with fuel air ratios in jet engines
  • Knowledge of combustion chemistry
  • Ability to interpret technical literature on propulsion systems
  • Research the specific fuel air ratios for various rocket fuels, including Oxygen/Hydrogen and Oxygen/Ethyl Alcohol.
  • Study the differences between pulse jet engines and rocket engines, focusing on their operational principles.
  • Examine the impact of varying oxygen percentages in air on combustion efficiency.
  • Explore advanced calculations for nozzle diameter in rocket propulsion systems.
Aerospace engineers, propulsion system designers, and students of rocket science will benefit from this discussion, particularly those focused on optimizing fuel efficiency in rocket engines.
gary350
What is the Air/Propane mixture Ratio?
The Fuel Air Ratio of a Jet Engine is 15 to 1. This is for JP4.
What is the Fuel Air Ratio for Propane Gas?
I have learned the only difference between a rocket engine and pulse jet engine is the pulse jet runs on the oxygen that is in the air (30% oxygen + 70% nitrogen) while the rocket engine runs on pure oxygen. Many of the formulas for calculating the nozzle diameter etc. are the same for both types of engines. In order to do the calculation for a pulse jet engine running on propane I need to know the Air Fuel Mixture Ratio for and Air/Propane mixture.
Confliction information here.
Book #1. Propulsion Systems for Guided Missiles.
Mixture ratio for Oxygen/Hydrogen is 5.33 to 1.
Mixture ratio for Oxygen/Ethyl Alcohol is 1.5 to 1.
Mixture ratio for Oxygen/gasoline is 3.0 to 1.
Mixture ratio for Oxygen/Propane is 4.5 to 1.
Book #2. Liquid Fuel Rocket Engines.
Mixture ratio for Oxygen/Hydrogen is 3.5 to 1.
Mixture ratio for Oxygen/Methyl Alcohol is 2.2 to 1.
Mixture ratio for Oxygen/gasoline is 2.5 to 1.
Mixture ratio for Oxygen/Propane is Not Available.
I assume if for example since air is 30% oxygen I should be able to divide the Oxygen mixture ratio for a Rocket Engine by .3 to get the Air/Fuel Mixture Ratio for a Pulse Jet Engine. Is it correct to assume this?
The mixture ratio of Oxygen/Propane is 4.5/1 then the mixture ratio for Air/Propane should be 4.5/.3=15 or 15/1.
Is this correct?
The future belongs to those who take risks! If you don't risk anything, you risk even more!
Chemistry news on Phys.org
The percentage of O2 is 21 percent not 30 percent. If the 4.5 is correct, 4.5 / .21 equals 21.4.
  • · Replies 26 ·
24K
  • · Replies 39 ·
  • · Replies 47 ·
9K
  • · Replies 19 ·
17K
