The amorphous borders between grains in a metal
  • Thread starter Thread starter rabbitweed
    Amorphous Metal
Metals are polycrystalline materials composed of distinct 'grains' separated by grain boundaries, which are often amorphous solids. In pure metals, grain boundaries exist due to the solidification process, leading to polycrystalline structures rather than single crystals. The discussion clarifies that while pure metals can theoretically form a single crystal, they typically do not due to kinetic limitations during solidification. Impurities in metals are usually present in the parts per million range, affecting the grain structure.
  • Understanding of polycrystalline materials
  • Knowledge of grain boundaries and their significance
  • Familiarity with solidification processes in metallurgy
  • Basic concepts of crystal lattices and orientations
  • Research the solidification process of metals and its impact on grain formation
  • Explore the role of impurities in metal grain structures
  • Learn about the properties and characteristics of grain boundaries in metallurgy
  • Investigate techniques for analyzing grain structures, such as electron backscatter diffraction (EBSD)
Engineering students, metallurgists, materials scientists, and anyone interested in the microstructural properties of metals and their implications in material performance.
rabbitweed
I am taking Engineering 101, and trying to get the hang of metal structure on a 'grains' level.
Ok, so my understanding is this;
Metals are polycrystalline materials, that can be divided up into 'grains'. These grains are basically crystals/lattices with a repeating pattern, separated by amorphous solids. The place where two grains are separated by an amorphous solid is known as a grain boundary.
All correct so far?!
Ok, my question is; say in a lump of Fe ore, would these amorphous solids separating the grains be made of Fe, or some impurity?
Does pure metal have grain boundaries? It would seem to me they would likely form one giant crystal...but my understanding is hazy.
Polycrystalline materials (metals and ceramics) imply 'grains' which are the subunits in a solid. Each grain has a given lattice orientation, and the grain boundaries are more or less amorphous due to the mismatch between the adjacent lattices.
Ores are metal oxides, sulfides, carbonates, . . . , but not pure metal.
One could conceiveably have a single crystal of pure metal or alloy, but more often pure metals are polycrystalline due to the nature of the solidification process. Impurities are usually present in the ppm range.
This isn't the best way to put it. There are regions of interrupted crystal arrangements between grains, but these regions are hardly "solids." If two grains are nearly aligned, the grain boundary can be as mild as a periodic dislocation, and nobody would say that this interface is amorphous.
Yes, essentially every metal you ever see will be polycrystalline. Although there's a driving force to form a single crystal (since the grain boundaries have a higher energy), the kinetic limitations are prohibitive.
  • · Replies 16 ·
