Special relativity and acceleration
The discussion explores the relationship between acceleration and time dilation, as well as acceleration and length contraction within the framework of special relativity. Participants examine the implications of Einstein's equivalence principle and how it relates to inertial and gravitational acceleration, including the effects on time dilation experienced by observers in different frames of reference.
  • Some participants propose that acceleration affects time dilation and length contraction indirectly by altering relative velocities.
  • Others argue that according to the equivalence principle, inertial acceleration should experience the same time dilation as gravitational acceleration, suggesting a deeper connection between the two.
  • A participant notes that comparing accelerated and unaccelerated observers is complicated by the increasing velocity difference, which can dominate time dilation effects.
  • There is a discussion about the time dilation experienced between different parts of an accelerating spaceship, with claims that the front experiences slightly less acceleration than the back, leading to a time difference analogous to gravitational time dilation.
  • Some participants express uncertainty about separating the contributions of velocity and acceleration to time dilation, with differing preferences for integrating proper time over the world line versus decomposing the contributions.
  • One participant raises a question about whether an accelerated frame would need to resynchronize its clocks after attaining a new inertial velocity due to asymmetric dilation effects.
Participants do not reach a consensus on the relationship between acceleration and time dilation, with multiple competing views and ongoing debate regarding the implications of the equivalence principle and the effects of acceleration on time dilation.
Some claims rely on specific interpretations of the equivalence principle and the nature of acceleration in different frames of reference, which may not be universally accepted. The discussion also highlights the complexity of comparing accelerated and unaccelerated observers, as well as the challenges in isolating the effects of velocity and acceleration on time dilation.
Zman
Is there a relationship in special relativity between acceleration and time dilation?
Or even acceleration and length contraction?
The primary relation is between relative velocities and dilation/contraction. Acceleration leads to changes in dilation/contraction factors, but only because it alters velocity.
It gets a bit subtle when you have two accelerating observers maintaining a constant separation along the direction of accelerated motion, according to their own accelerating frame of reference. In that case, there is a time dilation between the observers, which is analogous to the dilation observed with altitude in a gravitational field. You can still derive it from the underlying velocity based dilation. In SR (which does not deal with gravity) it all comes down to velocity.
Cheers -- sylas
The reason that I ask the question is that Einstein’s equivalence principle says (basically) that one can’t differentiate between inertial and gravitational acceleration.
If this is the case then an inertial acceleration of g should also experience the same time dilation as a body at a particular gravitational potential where the acceleration due to gravity is g.
For the gravitational body, its clock rate reference is zero gravity. For the inertial body, its clock rate reference would be an observer that was not accelerating but could have any velocity. The time dilation due to the velocity is not the issue here. Given the equivalence principle there presumably would be a time dilation contribution due to the acceleration otherwise the equivalent principle wouldn’t be entirely equivalent.
It does: and this is what I describe above in the previous post.
Note that you cannot simply compare an accelerated observer with an unaccelerated observer, because in that case you also get an increasing velocity difference, and that dominates any time dilation.
However, if you have a long spaceship experiencing a constant acceleration at all points, it turns out that the front has slightly less acceleration than the back, and there is a time dilation between the front and the back of the ship... but no change in the distance between them, as measured by anyone on the ship. THIS is what turns out to be exactly analogous to the time difference of two observers at different altitudes in a gravitational field.
Cheers -- sylas
Also, common statements about time dilation involve somewhat inconsistent interpretations. Special relativistic time dilation for moving clocks refers to the difference in elapsed coordinate times, not a visual effect that is actually seen through a telescope. In terms of visual effects, moving clocks can run fast or slow. Gravitational time dilation is a visual effect that can be observed through a telescope.
Why can’t we separate the velocity contribution to time dilation and the acceleration contribution to time dilation? At a particular point in time there will be a given velocity and a given acceleration.
Trying to work this one out, I keep getting more acceleration at the front (less at the rear). How did you work it out?
Cheers Zman
You can probably do that; but I would prefer to simply integrate proper time over the world line, without trying to decompose it. The point is that the case where there is a continually increasing relative velocity is not going to be a good match with a gravitational time dilation example.
I wrote it from memory, which is not totally reliable. Here's how I rethought it to answer your question... consider a particle with constant proper acceleration a, using the parametric equations, with u as proper time, and x and t as co-ordinates in a suitably chosen inertial frame.
[tex]\begin{align*}<br /> t &= \frac{c}{a} \sinh (ua/c) \\<br /> x &= \frac{c^2}{a} \cosh (ua/c)<br /> \end{align*}[/tex]​
Let this represent the front of the ship. Now imagine a photon sent backwards at a proper time u-d, and another received forward at time u+d. Their point of crossing defines a rear of the ship, which is a constant distance cd from the front. For a given u, let this rear be at (t', x') in the inertial frame.
Then
[tex]\begin{align*}<br /> x'+t'c & = \frac{c^2}{a} (\cosh ((u-d)a/c) + \sinh ((u-d)a/c)) \\<br /> &= \frac{c^2}{a} e^{(u-d)a/c} \\<br /> x'-t'c & = \frac{c^2}{a} (\cosh ((u+d)a/c) - \sinh ((u+d)a/c)) \\<br /> &= \frac{c^2}{a} e^{-(u+d)a/c} \\<br /> x' &= \frac{c^2}{a} e^{-da/c} \cosh(ua/c) \\<br /> t' &= \frac{c}{a} e^{-da/c} \sinh(ua/c)<br /> \end{align*}[/tex]​
Hence, the rear of the ship, identified in this way, has an acceleration a', and a proper time u', so that
[tex]\begin{align*}<br /> a' & = a e^{da/c} \\<br /> u' &= u e^{-da/c}<br /> \end{align*}[/tex]​
I'm taking d and a as positive, and so u' is running slow, just like a clock inside a gravitational well runs slow, and the acceleration at the rear is greater than at the front.
See also: Born Rigidity, Acceleration, and Inertia at www.mathpages.com
Cheers -- sylas
The reverse of that argument is that according to the equivalence principle, since time dilation occurs for observers "stationary" in an accelerated reference frame (like a rocket) then time dilation should also occur for observers stationary in a gravitational field. This is exactly how gravitational time dilation was predicted by Einstein.
=sylas;2273802]You can probably do that; but I would prefer to simply integrate proper time over the world line, without trying to decompose it.
What do you think about the tests that seem to indicate that the curvilinear component of the integrated world line due to acceleration, doesn't have an actual ,real world, time dilation correspondence?
Do you think that an accelerated frame , after attaining a new inertial velocity, would then have to resynchronize its clocks to compensate for this asymetric dilation of the rear clocks??
Thanks
I thought that this was not the case. That tests like Gravity Probe B , rotational acceleration tests and particle accelerator tests indicated that all observed dilation was due to the sum of instantaneous velocities with no actual dilation attributable to the acceleration itself. DO you have links to other findings? Thanks
What you say applies to the case when an inertial observer measures an accelerating object. In those conditions, dilation depends only on velocity and not on acceleration.
But it doesn't work the other way round, when an accelerating observer makes the measurement. In that case there is dilation depending on acceleration, even if the object being measured is a fixed distance from the observer in the observer's accelerating frame. The explanation for this is that a fixed distance in an accelerating frame becomes a Lorentz-contracting distance in an inertial frame, so there is movement and dilation.
In the context of the system I describe, there are two observers, one at the front and one at the rear of a spaceship. Both observers experience a constant acceleration, but the one at the front has a slightly smaller acceleration. The distance between the observers remains constant, as determined by either observer.
There can be no synchronization, and no re-synchronization. This is a steady state example which carries on indefinitely. As long as the acceleration remains constant and the distance remains fixed, the clock at the rear of the ship falls steadily behind the one at the front, because of the time dilation effect calculated.
This is a standard result, and can be calculated from special relativity. I gave a quick outline of the maths above. The conclusion has the status of a mathematical theorem. It's not just my guess about what goes on; it is the necessary implication of relativity for constant acceleration in a space ship.
Cheers -- sylas
Sure, time dilation for inertial observers is due to velocity, not directly due to acceleration. That's why I specified "observers "stationary" in an accelerated reference frame", since these accelerated observers will have relative velocity between them as measured in an inertial frame. The time dilation calculated from the inertial frame due to relative velocity will equal the "gravitational" time dilation measured by the accelerated observers due to their accelerated frame.
Another way to look at it is that gravitational time dilation is also solely attributable to relative velocity as measured in an inertial frame.
If you will check what I said you will see that I was specifically referring to after the period of acceleration [of whatever duration] , when the system was once again in inertial motion.
If one way light speed tests were conducted between the front of the system and the back,,, and the back to the front , do you think that
A --- The tests would result in c as usual?
B --- The tests would result in asymetric and incorrect results due to the desynchronization due to the greater dilation that had occurred in the rear clock.
The clocks would have to be resynchronized with light?
I was not questioning either the math or your command of the math, both are beyond me. ANy reservations I have are regarding the physical assumptions behind and the implications deriving from the conclusion. Thanks Stephen
=Al68;2278116]Sure, time dilation for inertial observers is due to velocity, not directly due to acceleration.
Are you referring here to the infinitesimal difference in acceleration or instantaneous velocity due to length contraction?
Measured how? Does this mean you would choose B in the post above?
Another way to look at it is that gravitational time dilation is also solely attributable to relative velocity as measured in an inertial frame.[/I
Intriguing concept I will have to give more thought to .
I was describing a continuous never ending constant acceleration. During this acceleration, the clocks run at different rates.
If acceleration stops, then the clocks will run at the same rate again, and so you can sychnronize them if you like. They'll certainly be out of sync after any period of acceleration, given that they were running at different speeds.
Of course, in most cases with which we are familiar, the spaceship is small or the acceleration is weak or the duration of acceleration is short, so that the dilation effect between front and back is very very small.
The speed of light is measured as c, in all cases, by all observers, accelerating or not.
Each clock is assumed to be perfectly correct in measuring the passage of time, in all conditions. They move out of sync because they are correct; because time dilation is a real effect that can be measured by correct clocks.
In a state where acceleration has stopped and the entire ship is moving at one constant velocity, you can sychnronize the clocks because they'll be running at the same speed. You can synchronize them however you like.
No problem. I understand that. I'm just explaining the nature of the assumptions I am making... namely, that relativity is correct. There's no other special assumption needed; the result is necessary consequence of the maths of relativity.
Technically, there's is an assumption of a "rigid" spaceship, which is a very natural assumption that you might not even think of. It means that the spaceship size remains always about the same for passengers on board. You don't have any continuous deformation or compression of the ship. You might not even think of this as an assumption, although it is needed in the derivations.
Cheers -- sylas
Given any kind of real world acceleration wouldn't the linear distance difference, in total path length between the front and back of the system over the full course of acceleration, be negligable in terms of relative velocity ? Or relative acceleration?
If the cumulative overall difference is slight wouldn't the instantaneous or slight interval difference be vanishingly small??
I am assuming that real world acceleration would mean that as system length and mass increased, that time of acceleration/path length would increase also. That if you consider a very long system where the contraction difference would be greater it would also take longer to achieve comparable velocities. ? Thanks
=sylas;2278316]
If acceleration stops, then the clocks will run at the same rate again, and so you can sychnronize them if you like. 1 They'll certainly be out of sync after any period of acceleration, given that they were running at different speeds.
2 The speed of light is measured as c, in all cases, by all observers, accelerating or not .3
Each clock is assumed to be perfectly correct in measuring the passage of time, in all conditions. 3 a [ B]They move out of sync because they are correct[/i[/B]]; because time dilation is a real effect that can be measured by correct clocks.
Would you agree that, by definition and convention, any set of clocks that measures the speed of light as c in both directions is synchronized ?
Would you agree that any set of clocks that are not synchronized within the terms of that convention, could not possibly measure the speed of light as c in both directions?
SO if you believe #2 above [which is what I believe] how do you justify #1 above.
In what sense can they be determined or even considered as out of synch if they return correct results for light tests?
In what possible way could the assumed dilation be empirically confirmed ,you think it is not perceived by outside observers in inertial frames and does not effect the functioning of clocks in some observable way within the system itself?
#3a What do you mean by correct in this context?
I have no question that time dilation is a real effect on real world clocks. But there is also no question that there is uncertainty and lack of consensus regarding the :
A physics involved. Is there physics involved?? Is it just a coordinate effect, a purely relative perception without any physical implications?? We see the same effect due to gravitational potential in which case we do assume an underlying physicality to the phenomenon.
B relationship to acceleration. The twins question. While it doesn't seem to actually produce dilation , it in some way is considered to turn relative[reciprocal] dilation, due to velocity, into a nonreciprocal phenomenon .
Kind of a catalytic effect. Whether or not this is correct it is certainly without explanation or reason to be found within the conceptual or mathematical structure of SR.
QUOTE] I'm just explaining the nature of the assumptions I am making... namely, that relativity is correct. There's no other special assumption needed; the result is necessary consequence of the maths of relativity.[/QUOTE]
I am certainly not questioning the assumption that SR is correct. But where in the Lorentz maths does it become inevitable that acceleration causes time dilation?
Without additional assumptions regarding the physics of acceleration.
Without the assumption that the perceived contraction relative to some inertial frame has actual physical meaning and implications. [which may be true but are not known or understood at this time]
Without the assumption of relativistic differentials of velocity between the front and the back.
This whole question seems to assume a conception of acceleration that is divorced from its basic meaning of a change of velocity over time. To disregard the D in D/t.
It seems to say that over the course of an acceleration, the total distance traveled by the rear [ R] dx relative to the total distance traveled by the front - [F] dx could be a relativistic velocity Fdx - Rdx/ t = [relativistically significant] v where Rdx = Fdx +gamma (length of system)
Does this seem realistic to you?
Thanks Stephen
No. As I have said, all clocks measure the speed of light as c. This applies for ALL clocks, whether they are synchronized or not.
No. All clocks measure the speed of light as c.
Both statements are false. This is fundamental.
In the sense that they run at different rates. Note that measurement of time AND length depends on the frame. Hence there is no contradiction with different observers measuring the same speed for light, even though they measure times and distances with different values. It is light speed that is the same for all frames; but not times or distances.
Time dilation is measured directly using clocks. There are many experiments doing this. My favourite is the family that measured a gravitational time dilation by carrying a small van with three atomic clocks up Mt Rainer for a holiday weekend. Dad took the kinds for an exciting and educational holiday, while Mum stayed home watching over atomic clocks left in the kitchen. It's described in [post=2177891]msg #10[/post] of thread "Gravitational Time Dilation - Confused".
A clock is correct if it let's you measure the passage of time.
There is only uncertainty and lack of consensus with students who don't actually know enough physics yet. The physics is completely unambiguous and any student who can pass an introductory course in relativity should get precisely the same answers. If they don't, then they they are wrong. Relativity is a consistent theory that is thoroughly tested and gives only one possible answer to these questions.
You've come to the right place to learn more about it... but make no mistake... you do need to learn more about it.
I gave the maths before. You can't simply use a Lorentz transformation; that only applies for mapping between non-accelerating frames. But with a bit of calculus applied as well, the result falls out.
This is a bit more advanced than just using the Lorentz transformation itself, but from your initial questions in this post, I think you are best to get thoroughly familiar with inertial frames, and measurement of light speed for inertial observers, before worrying about the accelerating case.
Cheers -- sylas
The latter.
No, of course not. The way I read that post, there is no proper acceleration when the measurement is taken.
The concept isn't new, this was the basis for Einstein's prediction of gravitational time dilation to begin with. I just worded it in a weird way for this thread.
Obviously, we can predict the elapsed time on each of two accelerated clocks between two defined events by using SR time dilation due to velocity relative to an inertial frame. We can then derive equations that can in turn be used in the accelerated frame to predict the same thing for the same clocks. Then we call it gravitational time dilation in the accelerated frame. That's essentially what Einstein did around 1908? Maybe there is a link to the paper online I could find.
Original Austin0
If one way light speed tests were conducted between the front of the system and the back,,, and the back to the front , after stopping acceleration ,,do you think that
=Al68;2280052] The way I read that post, there is no proper acceleration when the measurement is taken.
You were quite right ,the question was regarding after the cessation of acceleration.
But I would still definitely like to know what your answer would be.
Also I am unclear what means you are talking about when you say measured by the accelerated observers. DO you mean moving one of the clocks and making a direct comparison?
Finding an actual discrepancy in synchronization between the front and back??
Or with light tests revealing loss of synch??
There was a thread in the past, wherein I mentioned the possiblity of quasi gravitational time dilation, I was pointed to most of the actual tests I mentioned above, by someone in this forum, with the admonition that the EP didnt work this way. I thought I got it then but apparently I need to take another look.
Thanks
=sylas;2279626]No. As I have said, all clocks measure the speed of light as c. This applies for ALL clocks, whether they are synchronized or not.
By this do you mean; if you are aware of the desynchronization and know the degree of error you can make adjustments in calulation and testing to correctly get the value of c.
If you mean something else could you explain.
sylas;2278316]
#1
#2 The speed of light is measured as c, in all cases, by all observers, accelerating or not .
austin0--SO if you believe #2 above [which is what I believe] how do you justify #1 above.
= sylas Both statements are false. This is fundamental.
I think there is a little miscommunication here as both statements referred to here [#1 and #2]
were made by you . I just quoted.
That is not what I am trying to address here. I am familiar with how relative inertial frames all measure the same value for light speed. Through length contraction, dilation and dsynchronization. In this case we are talking about how can two different clocks within the same frame measure the same value for that speed in both directions if they are not synchronized.
This is my question. How the observers in an accelerated frame measure the time dilation and detect the relative dilation between the front and the back.
I am also aware of the gravitational tests and there is no question regarding gravitational dilation.
What I was referring to here was based on my reading here in this forum as well as other sources. I also wasnt referring to the fundamentals of SR or its application but to certain areas and questions growing out of the basics. If you read that paper on Born rigidity you linked in this thread, it touches on some of these. The possibility that inertia may in part be a matter of temporal resistance and other ideas. I have read any number of treatments of the Bell ship problem. They certainly didnt all agree on either the physical assumptions or conclusions. One actually applied two different assumptions regarding the way to calculate acceleration ,giving two different conclusions. The line snapped in one and not in the other case.
I have read many twins threads , where very knowledgeable people in this forum have presented quite different ideas of the problem. Some say it is resolved on the basis of acceleration. Others have said "no" , acceleration has no direct dilation effect but it is resolvable purely through simultaneity ,contraction and normal dilation.And others. These are not students I am talking about.
And then there are all the questions that nobody even pretends to know the answer to , which in fact may not be answerable, but still should be explored. The how behind the effects. A physical model that would explain length contraction etc etc. The question of whether or not that question has any meaning.
No argument there. On both counts Thanks
No, I mean that the speed of light really is c for all observers. There are no corrections or adjustments needed; anyone equipped with a clock and a ruler will measure the speed of light, directly, with the same value. No adjustments. It doesn't matter how fast they are moving, or how strong their local gravitational field, or how they are accelerating. Speed of light is still c.
Because it is not only time that is dilated. Distance measurements change also.
To measure the speed of light, you time how long it takes to get from one point to another, and also see how far apart the two points are.
Different observers may obtain different times for light to get from one point to another, because of time dilation. But they ALSO obtain different distances from one point to the other, and by the same factor. The speed is what remains unchanged.
The statements you quote HERE are from me, and they are correct.
The statements I commented upon in the previous post were NOT by me, and they were incorrect.
"Same frame"? What do you mean by "same frame"?
Clocks that are inside an accelerating spaceship, but at different locations in the ship, are not in the same frame, and they run at different speeds, due to a time dilation effect analogous to gravitational time dilation.
I think your use of the word "synchronized" is a bit odd here. The usual meaning is to make sure the clocks have the same reading at a given point in space and time. After that, the clocks may diverge from each other again, if they are not in the same frame.
Whatever method you choose for measuring gravitation dilation will also measure dilation within an accelerating spaceship. It's the same effect, after all.
However, the different ends of the accelerating spaceship are not the same frame, in the same way that the top and bottom of a tower are not the same frame.
You can get the same result with different methods. That's normal in maths, or physics.
In a situation that is impossible (like an infinitely rigid rod, or something like that) different people may propose different ways in which the situation "breaks down". Technically, that means they are looking at slightly different situations.
There are differences in the way this is put, and some people do actually get it wrong; even people that appear to be expert. I've made mistakes myself as well. We all make errors from time to time.
It's not a good idea, in my view, to try and calculate results using simultaneity, contraction, dilation etc. You can, but it's really easy to go wrong. You are best to calculate using Lorentz transformations (when working with inertial frames) or integrating proper time over world lines (which working with more general motions), and take the differences in simultaneity, time dilation, length contraction, etc, as consequences you can show from the basic calculation.
In my view, it is misleading to think of acceleration causing dilation. Acceleration is just a way of changing the motions; at every instant the time dilation for a clock in SR is always obtained by considering its relative velocity to your reference observer.
Cheers -- sylas
No, A is correct. The speed of light would be measured as c.
Any of the above. Like I mentioned above, the predicted difference in clock rates for between two accelerated clocks for an observer at rest with the clocks will be the same whether the prediction is made from an inertial frame (velocity based time dilation) or in the accelerated frame (gravitational time dilation). They're not really two different effects.
Thanks
I'm not sure what you mean by "quasi gravitational time dilation", but gravitational time dilation for clocks at rest in a gravitational field was predicted by applying the EP to the predicted time dilation for clocks in an accelerated frame (like a rocket).
sylas said:
"Same frame"? What do you mean by "same frame"?....
...However, the different ends of the accelerating spaceship are not the same frame, in the same way that the top and bottom of a tower are not the same frame.
I think he was referring to the accelerated frame defined as the spaceship being "stationary", or in which Earth's surface is stationary, not an inertial frame.
I don't think that is a "frame" in the proper sense of the word. There's an accelerated frame for the front of the ship, and another accelerated frame for the back of the ship, but since the actual acceleration is different at the front and at the back, you can't have a single "frame" for the entire ship. But I am not entirely sure of what the word "frame" encompasses.
It's analogous to the case of a tower in a gravitational field, with a clocks at the top and at the bottom of the tower running at different rates. The difference is simply that you can calculate the effect in the accelerating spaceship without using general relativity, but (by the equivalence principle) the net effect for clocks and rulers is the same.
Cheers -- sylas
Gentlemen it seems like there is a great deal of confusion and miscommunication here. I basically caused this when I entered a discussion about an accelerating system = S (a) ,,and started talking about after it stopped accelerating and was then an inertial system. = S ( i )
So I have been asking questions within the context of and regarding frame S ( i) and getting responces that related to system S ( a ) ,leaving me frustrated because I wasn’t getting answers to the actual questions I asked and you with the impression I was relativitively retarded..
I find the topic very interesting and appreciate the opportunity to get your input so I hope you will bear with me if I try to clear things up a bit
Here's the collated set of relevant posts
_____ POST 1_______________________________________________________
=sylas;2278316]
C Would you agree that, by definition and convention, any set of clocks that measures the speed of light as c in both directions is synchronized ?
D --Would you agree that any set of clocks that are not synchronized within the terms of that convention, could not possibly measure the speed of light as c in both directions?
POST 2_________________________________________________________________________
POST 3
___________________________________________________________________________
POST 4
____________________________________________________________________________
Sylas
DOes this mean then that you think that the statements above C ,D are wrong??
C ---- By definition and convention, any set of clocks that measures the speed of light as c in both directions is synchronized ?
D----
Sylas [
B]I think your use of the word "synchronized" is a bit odd here. The usual meaning is to make sure the clocks have the same reading at a given point in space and time. After that, the clocks may diverge from each other again, if they are not in the same frame.
[/B]
Of course that is the fundamental definition. But Einstein and SR also provide a means of achieving and testing synchronization with clocks that are spatially separated . Initially through two way reflected light transmissions/2 and also through one way transmissions with an agreed upon transmission time. The end result is exactly the same. This is also part of the SR convention regarding synchronization.
SO do you think wrt statement C above; that clocks that passed this test could possibly be unsynchronized? By what definition??
Do you think that clocks that were not synchronized , ie: didnt read the same time while collocated or had different readings at different locations could possibly measure light at c?
Self evidently,,, but it also assumes that since the clocks are apart they must be synchronized. SO they must either be synched while collocated and moved apart or synched by the light method.
In the accelerating ship it is assumed they started out synched while collocated but went out of synch while they were separated. SO to observe any desynch would neccessitate either moving them together or being able to detect it by light tests while separated.
SO do you think that in this circumstance you could move the clocks together and detect different time readings but then move them back apart and get correct readings for c? If you consider them to be in two different frames how could they correctly measure c in any case. SR says that any two synched clocks in any single frame will always measure c in both directions.
Do you think it says that light measurements between a single clock in one frame and a single clock in a second frame would, that they could be in synch?
Sorry I was simply using the word frame when I should have said system.
I hope the questions are becoming clearer Thanks Stephen
=Al68;2282124]No, A is correct. The speed of light would be measured as c
Any of the above.
It seems like you are choosing both A and B
In case there is confusion between the accelerating system S (accl) and the inertial system S ( inrt) after acceleration.
So : S (accl) A or B ?
S ( inrt) A or B ?
Thanks for your patience Stephen
I cannot tell whether you are just quoting old material, or whether you are asking the same questions again. But the answers are unchanged.
You seem to be asking, again, "Would you agree that, by definition and convention, any set of clocks that measures the speed of light as c in both directions is synchronized".
The answer is still an easy NO. Definitely and unambiguously not.
ALL observers ALWAYS measure the speed of light as "c". That means that clocks which are NOT synchronized... whatever you mean by that... will STILL measure the speed of light as c in both directions.
There are two possible ways you can mean synchronized. One is that clocks are synchronized if they are set to read the same value at a single point in space and time. It doesn't matter if they are moving relative to each other; as long as they pass right next to one another then you can ensure both read the same value in that shared instant.
The other is that clocks which are in the same frame (and hence are not dilated with respect to each other) can be synchronized to read the same value at the same time. You can do this because they share the same frame, and hence share the same notion of what is simultaneous.
But you can't synchronize clocks that are moving with respect to each other and are also separated from each other... because those two clocks don't have a common concept of "simultaneous". You can't make them read the same value at the same time because they don't agree as to what "at the same time" implies.
None of this makes any difference for measuring the speed of light. ALL observers always measure the speed of light, in any direction, as c. Whether they are synchronized or not.
Cheers -- sylas
There's a misunderstanding here between Austin0 and sylas; you are talking about different things without realising it.
When Austin0 talks of "a set of clocks measuring the speed of light" he means you send light from clock A to clock B, measure the time of emission on clock A, measure the time of reception on clock B, and subtract the two times to give the time of transit. That method works when both A and B are stationary relative to the same inertial frame and the clocks have previously been synchronised in the standard way. It won't work when A and B are both stationary relative to the same accelerated frame, because, as has already been established, the clocks cannot stay in synchronisation.
On the other hand, sylas has in mind that each clock makes its own measurement of the local speed of light, independent of any other clocks. What does that mean? How do accelerating observers measure speed? The technical answer is that an accelerating observer asks an inertial oberver who happens to be momentarily traveling at the same speed (a "co-moving inertial observer") to make the measurement instead. In practice you can achieve the same end by using two clocks that are only a small distance apart (so the desynchronisation is negligible), or better still, consider the mathematical limit as the distance between the two clocks tends to zero. When an accelerating observer uses this method, they always measure the speed of light as c. That's what sylas meant.
Hopefully you will each realize what the other was talkiing about and can now continue this thread in less confusion!
  • · Replies 26 ·
  • · Replies 79 ·
  • · Replies 27 ·
