Wave Help: Solving Standing Wave and Interference Problems
  • Thread starter Thread starter avs
    Wave
The discussion revolves around two physics problems related to wave mechanics: one involving standing waves on a string and the other concerning interference patterns from point sources. The first problem requires evaluating frequencies, sketching wave patterns, and determining maximum velocities and accelerations. The second problem focuses on identifying angles of constructive and destructive interference from two point sources emitting waves.
  • Mixed
  • Participants explore calculations for standing wave frequencies and question the correctness of their evaluations. There is a focus on understanding the relationship between wave properties and physical parameters such as tension and mass per unit length.
  • Some participants seek clarification on the distinction between wave velocity and transverse velocity at nodes, indicating confusion about the definitions and implications of these terms.
  • Questions arise regarding the setup of the standing wave equations and the proper application of formulas for velocity and acceleration.
Some participants have confirmed calculations related to standing wave frequencies, while others express uncertainty and seek validation of their results. There is an ongoing exploration of the correct approach to calculating transverse velocities and accelerations, with guidance provided on the need to reference the displacement equation for standing waves.
Participants are working under the constraints of homework assignments, which may limit the information they can provide or the methods they can use. The discussion reflects an emphasis on understanding concepts rather than simply arriving at answers.
avs
I am stuck with these 2 questions. Can someone help. THanks
1. A string is tied tightly between two fixed points 0.7 meter apart (along the x-axis) so that its tension is 9N. A 3 meter length of the same string has a mass of 18g. Very small oscillations of one of the fixed points at a carefully chosen frequency, cause a corresponding transverse standing wave mode to be set up. Assume the oscillations are small enough that both sides of the strings are nodes. The modes are set up one at a time. In all cases the maximum displacement of any part of the string is 2.0mm from the x-axis and lies in the y-direction.
a. Evaluate the two lowest standing wave frequencies, f.
b. Sketch the standing waves corresponding to the two frequencies in (a) labeling each with its correct frequency.
c. Determine the maximum accelerations and velocities (vector!) that exist in the above standing waves.
d. For each of the answers to part ( C ), show on a sketch where the string is in its cycle and where on the string each maximum is to be found.
2. Consider two points sources located at (x1=3 cm, y1=z1=0) and (x2=-3cm, y2=z2=0) respectively. They are emitting identical waves which spread out equally in all directions (spherical wave fronts). The wavelength is 2.3 cm. The two sources are oscillating in phase with each other.
a. In the x-y plane at large distances from the sources, find all the angles from the y-axis at which you would find constructive interference.
b. Similarily find all the angles at which you would find destructive interference.
c. Bearing in mind the three dimensional character of the problem, sketch a perspective view showing where destructive interference occurs.
d. Suppose now that the two sources are exactly pi/2 radians out of phase with each other. Again find the angles at which destructive interference and again sketch a perspective view.
What aren't you understanding and please show us where you are getting stuck.
Thanks
Ok just want to confirm if 1a is correct.
thanks a lot!
First K1=(pi/L)=4.5m^-1 K2=(2*pi)/L=9.0m^-1
Now Lambda(1)=(2*pi)/K1=1.4m Lambda(2)=(2*pi)/K2=0.7m
f*lambda=(T/mu)^1/2 mu=0.018kg/3m=0.006kg/m
f1=27.7 f2=55.33
Yes, you did that correctly.
ok for 1c:
1st node:
v=f*(lambda) lambda=2L=1.4m
V=27.7*1.4m=38.8m/s
2nd node:
lambda=L
V=55.33*0.7=38.7m/s
For acceleration:
V=f*lambda=(lambda/tau)
dV/dTau=(-lambda/tau^2)
tau=1/f
plug everything in i got
node1:
a=1.4/0.0361^2=1074.2m/s^2
node2:
a=0.7/0.01807^2=2143m/s^2
Just want to confirm if this is correct. Thanks
Originally posted by avs
ok for 1c:
1st node:
V=27.7*1.4m=38.8m/s
2nd node:
lambda=L
V=55.33*0.7=38.7m/s
First, you aren't evaulating the velocity at any "node". A node is a point that does not move at all.
Second, you are computing the wave velocity, and that is not what they are asking for. They are asking for the transverse velocity, the velocity at which a point moves up and down.
You'll need to start with the equation for the displacement of a standing wave:
y(x,t)=ymsin(kx±ωt).
For acceleration:
tau=1/f
node1:
node2:
Since you started from the wrong point, this is wrong too. You'll need to work it from y(x,t), given above.
  • · Replies 21 ·
  • · Replies 19 ·
