If y=x^x then what is x in terms of y?
  • Context: Undergrad
  • Thread starter Thread starter 3hlang
    Terms
The discussion revolves around the equation y = x^x and the challenge of expressing x in terms of y. Participants explore whether this can be achieved algebraically or through other means, including the use of the Lambert W function.
  • Some participants suggest that finding x in terms of y can be done through iteration, while questioning the possibility of an algebraic solution.
  • One participant proposes taking the logarithm of both sides, leading to the equation ln(y) = xln(x), and introduces the Lambert W function as a potential solution, stating that x = W(ln(y)).
  • Another participant notes that standard functions do not suffice for this problem, hence the relevance of the Lambert W function.
  • A participant poses a related question about the inverse scenario, asking what y would be if x = y^y, and applies the same logarithmic approach to derive y = W(ln(x)).
  • There is a clarification that the previous manipulation simply involves swapping x and y, not altering the fundamental approach.
Participants express differing views on the feasibility of an algebraic solution, with some supporting the use of the Lambert W function while others question the algebraic nature of the approach. The discussion remains unresolved regarding the broader implications of these manipulations.
The discussion highlights the limitations of standard functions in solving the equation and the specific conditions under which the Lambert W function is applicable. There is also an implicit assumption regarding the definitions and properties of the functions involved.
3hlang
i know this is possible to find with iteration, but is it possible to find it algebraically?
Mathematics news on Phys.org
Hi 3hlang! :smile:
Nope!
This probably isn't what you mean by "algebraically" but if you take the logarithm of both sides of the equation you get ln(y)= xln(x) and then x= W(ln(y)) where W is the "Lambert W function" which is defined as the inverse function to xln(x).
... and the reason we talk about the Lambert W function is that none of the previously-defined standard functions would work.
so if x=y^y, then y=?
All you have done is swap x and y! If [itex]x= y^y[/itex] then, by the same formula I gave before, y= W(ln(x)).
what? i wasn't claiming to have done anything radical to the formula. all i wanted to know was what you do the w function of. but thank you for telling me
  • · Replies 48 ·
  • · Replies 16 ·
  • · Replies 19 ·
