Understanding Leibnitz Notation for Differential Equations
  • Thread starter Thread starter James889
    Notation
The discussion revolves around understanding Leibnitz notation in the context of differential equations, specifically focusing on the expression \(\frac{d}{dx}\frac{y}{x^2}\) and its implications in solving a differential equation.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the meaning of the derivative notation \(\frac{d}{dx}\frac{y}{x^2}\) and question why it equals 1. Some suggest using the product rule for differentiation, while others emphasize understanding the implications of the derivative being equal to 1.
Participants are actively discussing the notation and its meaning, with some providing guidance on differentiation techniques and the implications of the results. There are multiple interpretations being explored regarding the significance of the derivative equating to 1.
Some participants express confusion regarding the notation and terminology used in calculus, indicating a need for clarification on basic concepts. The discussion also touches on the relationship between the derivative and the solution to the differential equation.
James889
Hi,
I was looking at a solution to a differential equation problem. And there are some parts that i don't understand.
[tex]\frac{dy}{dx} - \frac{2y}{x} = x^2[/tex]
And the solution looks like this:
[tex]e^\int{ \frac{-2}{x}} = \frac{1}{x^2}[/tex]
[tex]\frac{1}{x^2}\frac{dy}{dx} -\frac{2}{x^3}y=1[/tex]
[tex]\frac{d}{dx}\frac{y}{x^2}=1[/tex]
This is the part i don't understand, what does [tex]\frac{d}{dx}\frac{y}{x^2}[/tex] mean, and why is it equal to 1 ?
To be honest i find this notation pretty confusing.
Hi James889! :smile:
It just means d/dx of y/x2
use the product rule, and that's (dy/dx)(1/x2) + y(-2/x3) …
which is the LHS of the previous line! :wink:
Because
[tex]\frac{d}{dx}( \frac{y}{x^2}) = \frac{1}{x^2}\frac{dy}{dx}- \frac{2}{x^3}y[/tex]
James889 said:
Hi,
What that means is that you differentiate [itex]yx^2[/itex] with respect to x! That's pretty basic terminology. If you going to study calculus, you had better learn it:
[tex]\frac{df}{dx}[/tex] means "differentiate f with respect to x".
In this case, y is a function of x so we need to use both the product rule and the chain rule.
[tex]\frac{d yx^2}{dx}= \frac{dy}{dx}(x^2)+ y\frac{dx^2}{dx}[/tex]
exactly what is on the left side of your equation above. It is equal to one because it is equal to the left side of the equation whose right side is 1: If A= B and B= C then A= C.
James,
You're not asking the right question. The question is not why that derivative is 1, but what does it mean that that derivative is 1. The equation is
[tex]\frac{d}{dx} \frac{y}{x^2} = 1[/tex]
This is saying that the derivative wrt x of y/x2 = 1, which can only be true if y/x2 = x. This means that y/x2 = x ==> y = x3. Notice that this is the solution of the given differential equation.
Mark44 said:
… This is saying that the derivative wrt x of y/x2 = 1, which can only be true if y/x2 = x.
plus a constant! :wink:
Hello,
What is the difference in meaning between these notations?
[tex]\frac{dx}{e^x}[/tex] and [tex]e^x dx[/tex]
Hello James889! :smile:
(try using the X2 tag just above the Reply box :wink:)
There's nothing special about dx "over" something …
(unless the "something" also starts with "d", of course!)
dx/ex is the same as (1/ex)dx :wink:
James889 said:
Hello,
That's a peculiar question!
[itex]e^x dx[/itex] is dx times [itex]e^x[/itex] and [itex]dx/e^x[/itex] is dx divided by [itex]e^x[/itex]
You could also write [itex]dx/e^x[/itex] as [itex](1/e^x)dx[/itex] or [itex]e^{-x}dx[/itex].
Yes yes, I am not the sharpest knife in the box :rolleyes:
Right, but in the DE the constant was zero, so I omitted it in that step.
  • · Replies 18 ·
  • · Replies 21 ·
