Motor Ratings: 12V, 2 Ohm/Winding: How Much Current?
The discussion revolves around the current requirements and operational characteristics of a 12V, 2 Ohm/winding rated bipolar stepper motor. Participants explore how to drive the motor effectively, the implications of using different voltages, and the setup involving an L298 driver chip. The conversation includes practical testing and troubleshooting of the motor's performance.
  • Experimental/applied
  • One participant calculates the current needed using Ohm's law, suggesting that 6A is required to drive the motor at full power.
  • Another participant confirms the calculation but notes that the motor can operate at lower voltages with reduced power, emphasizing the need for testing due to the lack of a datasheet.
  • Concerns are raised about the motor's inability to rotate when powered by a 9V battery, with questions about whether insufficient current is the cause.
  • Discussion includes the possibility of needing two drivers for the stepper motor and the suggestion to consider whether a geared DC motor might be more suitable.
  • Participants clarify the motor type, indicating it is likely a bipolar motor based on the number of wires, and discuss the wiring setup with the L298 driver.
  • One participant expresses interest in acquiring a different stepper motor that requires less current, questioning if the current limitation is affecting the motor's movement.
  • Another participant mentions that there are stepper motors with 4 wires that may have a common wire, indicating variability in motor designs.
  • Suggestions are made to create a higher-powered dual H Bridge using power transistors if the L298 is insufficient for the motor's requirements.
Participants do not reach a consensus on the exact current requirements for the motor or the effectiveness of the L298 driver. Multiple competing views on the motor's operation and setup remain unresolved.
Limitations include the absence of a datasheet for the motor, uncertainty about the motor's winding configuration, and the lack of definitive testing results to confirm operational parameters.
Individuals interested in stepper motor operation, motor driver configurations, and practical electronics testing may find this discussion relevant.
saad87
I've got a 12V, 2 Ohm/winding rated motor and I'm trying to figure out how much current it'll take. From Ohm's law 12/2 = 6A - and that's a lot!
Is this much current needed to drive the motor? Can I use a lower amount of current? If so, how do I limit it?
I don't have the datasheet for the motor. It does have a model number, but a google search did not reveal anything.
Its a bipolar motor - only guessing because its got 4 wires coming out of it.
That Ohms Law calculation looks OK.
It will rotate at lower voltages but with less power. But if you don't have data, you will have to test the motor.
Does the motor have two windings or four? If it is two, are they isolated from each other?
You can put a voltage across the windings and watch for the shaft to step. It happens very fast, so put a mark on the shaft so you can see if it has happened.
Once it moves, you have to put the voltage across another winding or reverse the polarity across that one to get more rotation.
When you can predict which way the motor is going to turn, try holding it with your fingers to get an idea of how much power it has at lower voltages than the rated 12 volts.
Try to work out how many degrees it is turning each time it steps.
Hi, I just finished wiring up the 2nd half - the L298 chip. I, again as a test, attached 4 LEDs + some resistors at its 4 outputs and whenever I apply the clock, it changes its output.
So I think that's good.
However, when I attached the motor and powered up with the 9V battery, the motor just stood in one place. It did take some force to move the motor, so it was working. But it didn't move whenever I applied the pulse.
It took less force to move it when I attached the wallwart (5V, 1A).
Howcome its not rotating on its own? Is it the current? Do I need more? The max. I can supply is 2.5A due to the limitation of L298.
How did you attach the stepper motor without testing it?
Have a look at the lollowing page which explains the operation of stepper motors quite well.
http://www.haydonkerk.com/ResourcesandDownloads/StepperMotorTheory/tabid/192/Default.aspx
In the diagrams follow the movement of the rotating north pole.
You should need two drivers for a stepper motor and they may have to be made up from power transistors to carry the large current of that motor. See fig 5 in the above reference which shows two H Bridges.
Do you really need a stepper motor, or would a geared down DC motor be better? You could drive that with just one H bridge. Stepper motors might be a bit difficult for you at this stage.
Well, from what I've read Unipolar motors have 5 wires coming out of them and mine only has 4. So I'm assuming mine is a bipolar motor with one winding per phase, as there is no common.
I attached one winding (2 wires) to one set of outputs of the L298. And the other to second set of outputs. The L298 is a Dual H-Bridge driver. I made sure that a pair of wires did, infact, form a winding by measuring the resistance between them.
I might get another stepper motor, however (they're cheap here). Something which demands a lesser current.
But I just wanted to know if you do think its the current that's limiting the motor's movement?
There are stepper motors with 4 wires where one is common and the others are fed in sequence. I have several of those.
You need 2 H Bridges but the L298 has two in it already. BUT they are not capable of driving that motor apparently. Are you still using 9 V batteries?
An alternative would be to make up a higher powered dual H Bridge with power transistors if you needed the power of that motor.
  • · Replies 23 ·
18K
10K
