Help w/ Humminbird Marine GPS unit
  • Thread starter Thread starter DaveC426913
    Gps Marine Unit
The Humminbird 383 GPS unit does not determine orientation based on the device's physical position but rather through movement. When stationary, the device inaccurately indicates direction, often defaulting to NE instead of the actual SW. The issue resolves itself upon movement, as the GPS recalibrates based on the direction of travel. Users should understand that orientation is only established when the unit detects movement.
  • Understanding of GPS technology and its functionality
  • Familiarity with marine navigation equipment
  • Basic knowledge of Humminbird products and their features
  • Awareness of how movement affects GPS orientation
  • Research the calibration process for Humminbird GPS units
  • Learn about the differences between GPS positioning and orientation detection
  • Explore user manuals for troubleshooting common GPS issues
  • Investigate how movement influences GPS accuracy in marine environments
Boaters, sailors, marine navigators, and anyone using Humminbird GPS devices who seeks to understand orientation and movement-related functionality.
DaveC426913
2025 Award
Anyone here into sailing or boating?
I haven't left my mooring yet, been testing it at anchor but my new Humminbird 383 insists I'm pointing NE when I'm actually pointing SW.
It changes its mind every so often, occasionally it's correct, but seems to return to this position. I've left it for a half hour or more. I've tried hand-holding it and turning it, doesn't seem to register the rotation.
Am I missing something? Is there a configuration I need to go through? (For a while, I wondered if there was a flip northern/southern hemisphere setting or somesuch)I haven't left my mooring yet, been testing it at anchor but my new Humminbird 383 insists I'm pointing NE when I'm actually pointing SW.
Am I missing something? Is there a configuration I need to go through? (For a while, I wondered if there was a flip northern/southern hemisphere setting or somesuch) Does it need a milk-run to get its bearings? (Years go, my car compass wanted me to drive in circles until it locked on North.)
I've checked the GPS satellite display; it seems to be receiving several. There's nothing in the manual.
Computer science news on Phys.org
Never mind. Mystery solved.
As soon as we started moving, it immediately knew which way we were pointed. And, the moment we stopped again, it lost track of our orientation.
Conclusion: A GPS device does not determine one's orientation by determining the orientation of the device itself; it determines one's orientation by determining one's movement and then assuming one's orientation is pointed in the direction of movement.
i.e. if you're not moving, you have no orientation.
Also, if you are under power decide to throw it into reverse, presumably the unit will show your orientation as rearward.
  • · Replies 17 ·
