Calorimetry: q NH4NO3 Dissolving + Exothermic/Endothermic?
  • Thread starter Thread starter webz
The discussion focuses on calculating the heat ('q') associated with the dissolution of 20g of ammonium nitrate (NH4NO3) in 125g of water using a coffee-cup calorimeter. The temperature change observed is from 23.5°C to 13.4°C, resulting in a calculated q of +5.28 kJ, indicating that the process is endothermic. The heat capacity of water is utilized for the calculation, as the heat capacity of the solution is not provided. The number of moles of NH4NO3 is not necessary for this calculation since the question does not require the molar heat of dissolution.
  • Understanding of calorimetry principles
  • Knowledge of heat capacity calculations
  • Familiarity with temperature change (ΔT) concepts
  • Basic stoichiometry related to moles and molar mass
  • Learn about the heat capacity of solutions and its implications in calorimetry
  • Study the concept of molar heat of dissolution and its calculations
  • Explore advanced calorimetry techniques for more accurate measurements
  • Investigate the thermodynamic principles behind endothermic and exothermic reactions
Chemistry students, educators, and professionals involved in thermodynamics and calorimetry, particularly those studying reaction heat changes in solutions.
webz
20g of NH4NO3 (MM=80.05 g/mol) if dissolved in 125g of water in a coffee-cup colorimeter, the temperature falls from 23.5C to 13.4C. Determine 'q' for the dissolving of the compound. Is the process exothermic or endothermic?
q(calorimeter)=C(calorimeter)*[Delta]T
[Delta]T= -10.1
C(calorimeter)=~n(water)*C(water) = 125g H2O/18.016g/mol = 6.9382mol H2O
Ccal=~6.9382mol H2O* 75.291 J/mol C = 522.4 J/C
qcal=52.4J/C*-10.1C= -5.28kJ
q(calorimeter)= -q(chemical) = +5.28kJ
This answer makes sense, however, I don't understand why I am not taking into account the amount of moles NH4NO3. A larger amount of moles would make a larger deviation in T, which would change q.
Why are moles NH4NO3 not taken into account? Also, I'm using the heat capacity (C) of water, not of NH4NO3. The question is asking for 'q' for the dissolving compound. Is this correct?
To be precise you should take into account heat capacity of the solution - not water nor amonium nitrate. It is solution that changes temperature (well - this is more complicated - at first it is pure water that changes temperature, later it is solution, but it doesn't matter at the end). You are not given heat capacity of the solution, so you used heat capacity of water, which is the best approximation available to you.
You were asked to determine amount of heat needed for dissolving the compound - and looks like you did OK.
Number of moles will be required if the question asked for molar heat of dissolution - but it didn't.
20K
19K
  • · Replies 16 ·
32K
11K
18K
23K
18K
10K
