Why is my computer showing inconsistent free disk space readings?
  • Thread starter Thread starter Kenneth Mann
    Capacity Disk
The discussion revolves around the inconsistent readings of free disk space on an older computer running Windows XP. Participants explore potential causes for the fluctuating values displayed in the system, considering both hardware and software factors.
  • One participant notes that the free space readings fluctuate dramatically, sometimes showing as low as a few hundred kilobytes and other times as high as 17 gigabytes.
  • Another suggests that disk compression might be a factor, although they acknowledge that it shouldn't cause such extreme fluctuations.
  • A different participant raises the possibility of a failing hard drive, recommending backing up important data and replacing the drive.
  • One participant proposes that the swap file could be responsible for the varying free space readings, as it adjusts based on the system's memory needs.
  • Another participant mentions the use of a disk defragmenter as a potential solution, although they express uncertainty about its effectiveness.
  • A later reply confirms that the swap file does indeed grow and shrink based on program usage, which could explain the observed behavior.
  • The original poster indicates that they have replaced the hard drive with a larger one, which they hope will resolve the capacity issues.
Participants express multiple competing views regarding the cause of the inconsistent free disk space readings, with no consensus reached on a single explanation.
Some assumptions about the system's configuration and the nature of the swap file are not fully explored, and the discussion does not resolve the potential implications of a failing hard drive.
Individuals experiencing similar issues with disk space readings on older computers, particularly those using Windows XP, may find the discussion relevant.
Kenneth Mann
I just picked up an older computer (Dell with XP) to substitute for and eventually augment a machine that has turned boat-anchor on me (I'll get to that one at a later date). The main problem is the readings I get from "my computer" of the remaining "free space". Sometimes it reads as low as a few hunderd kilobytes. Other times as high as 17 gigabytes (from a total of 40). These readings can occur a few minutes apart - - - it's quite confusing. Does anyone have any idea why?
KM
Computer science news on Phys.org
Maybe the disk is compressed? Still shouldn't jump around like that. If you suspect that this is a platter or drive head failing, I'd buy a new hard drive, back up anything important and then reinstall Windows.
Thanks. The disk isn't compressed, however I'll have to get a new drive anyway. This one is going to be completely full once all the updates have been added. The previous user apparently never bothered with updates.
Possibly it's the swap file?
Have you tried the disk defragmenter?
I am not sure it will help but it may be worth a try.
It is the swap file. Unless you tell it otherwise, it grows and shrinks according to how many programs you are running at once. It temporarily stores stuff for which there is not enough room in memory at any given moment in time.
Thanks, the swap file answer seems to be a likely one. In any case, the disk has been replaced with one considerably larger, and that should hopefully solve the capacity problems. There's ample disk space for now and the forseeable future.
KM
  • · Replies 19 ·
11K
