Calculate Charge on Each Sphere: Force and Total Charge Given
  • Thread starter Thread starter jmb07
    Charge Force
The discussion revolves around calculating the charge on two metal spheres given their total charge and the repulsive force they experience when separated by a certain distance. The subject area involves electrostatics and the application of Coulomb's law.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationship between the charges on the spheres and the total charge, with attempts to express one charge in terms of the other. Questions arise regarding the algebraic manipulation needed to solve for the individual charges.
Some participants have offered guidance on how to set up the equations based on the total charge and the force equation. There is an acknowledgment of algebraic challenges, with one participant considering the use of the quadratic equation to find a solution.
Participants express uncertainty about their algebraic skills and the complexity of the equations involved, indicating a potential barrier to progressing in the problem-solving process.
jmb07
total charge of 6.63E-6 C distributed on 2 metal spheres. When the spheres are 6 cm apart, they each feel a repulsive force of 26.9 N. How much charge is on each sphere??
I know that F=(k x q1 x q2)/(r x r)
Im not exactly how to solve for these when i don't know either one of them to solve for one another. How should i go about this??
You can use the fact that q1+q2=6.63E-6. Use it as your second equation.
how would i relate q1 to q2? Like i understand that the two added together is the total charge.
Should i say that q2 = (F rxr)/(k x q1)
and q1 = 6.63E-6 - q2
I try plugging the relations in but i can't seem to put it all together for some reason
If
[tex]Q_1+Q_2=6.63e^{-6}[/tex],
then
[tex]Q_1=6.63e^{-6} - Q_2[/tex]
Substituting that back into your Force equation:
[tex]F=k\frac{(Q_1)(Q_2)}{r^2}[/tex]
[tex]F=k\frac{(6.63e^{-6} - Q_2)(Q_2)}{r^2}[/tex]
Solve for Q_2. In this way, you have used the value of Q2 to state the value of Q1 and your equation is then only dependent on the one variable, Q2, instead of two. After finding Q2, you should be able to figure out Q1 in one step.
thanks! I think i am having an algebra block though haha. So,
(6.63E-6 - q2)(q2) = (Frxr)/k
Do i need to use the quadratic equation to solve for q2 or is there a more simple way i am missing?
It appears to be unavoidable. It's not exactly difficult =)
  • · Replies 18 ·
