Why Does Water Balloon Drop Not Match Expected 9.81m/s² Acceleration?
The discussion revolves around an experiment involving the drop of water balloons and the observed acceleration, which does not match the expected value of 9.81 m/s². Participants are exploring the factors influencing the acceleration of non-rigid bodies in free fall.
  • Participants discuss the nature of the water balloon as a non-rigid body and question how this affects its acceleration. There are inquiries about the measurements taken, including height and time, and considerations of air resistance and terminal velocity.
The conversation is ongoing, with participants providing insights into the effects of air resistance and the definition of rigid bodies. There is a focus on understanding the discrepancies in acceleration measurements, but no consensus has been reached.
Participants are considering the impact of external factors such as air resistance and the conditions under which the measurements were taken, including the height of the drop and the timing of the observations.
psychosushi
I did an experiment with water balloons and i dropped it off at a specific height. The acceleration of the object is nowhere near 9.81m/s^2
Why is that?
Welcome to PF:
If you drop a rigid body, its acceleration due to gravity will be nearly 9,8 m/s^2
But the water balloon is not a rigid body.
rl.bhat said:
Welcome to PF:
rigid as in?
psychosushi said:
rigid as in?
Well, rigid in this context means "doesn't deform in any way." Every point within that body remains at a fixed position relative to all the other points, and these relative positions don't change. This is an idealization. There is no such thing as a rigid body in real life.
If I had been answering your original question, I would have cited air resistance (drag) as something to be looked into. I.e. you are not dropping this thing in a vacuum, and therefore gravity is not the only force acting on it.
thank you very much
Why is that?
What did you get for the acceleration?
More importantly, for what height and time did you make the measurements?
The oscillations of the balloon and the approach towards the terminal velocity (When the velocity is at the terminal velocity, the balloon will no longer accelerate) could have immense impacts on the average acceleration, flooring its value if you take a measurement over a long enough time.
  • · Replies 32 ·
