Acceleration of 50kg vs 75kg Object: Find the Ratio
The discussion revolves around comparing the acceleration of two objects with different masses, specifically a 50 kg object being pulled with a net force and a 75 kg object undergoing a change in velocity over a distance. Participants are exploring the calculations related to acceleration in the context of Newton's second law and kinematic equations.
  • Mixed
  • Participants discuss the application of formulas for calculating acceleration, questioning the use of time in accelerated motion versus constant velocity. There is exploration of average velocity and its role in determining time and acceleration for the 75 kg object.
Some participants have provided hints regarding the correct approach to finding time and average velocity. There is ongoing exploration of the relationship between the two objects' accelerations, with no explicit consensus reached on the final answer.
Participants are navigating the constraints of applying kinematic equations correctly, particularly in distinguishing between constant velocity and accelerated motion. There is a focus on ensuring the correct interpretation of average velocity in the context of the problem.
dance_sg
A 50.0 kg object is pulled along a horizontal surface with a horizontal net force of 250 N. A second object with a mass of 75.0 kg travels 4.00 m while changing its velocity from rest to 4.00 m/s. How many times greater is the acceleration of the 50.0 kg object than that of the 75.0 kg object?
a=Fnet/m, v=d/t, a=v/t
i tried finding acceleration of the 50 kg object by a=f/m which was 5m/s2. then to find acceleration of the 75kg object i used t=d/v to find the time so that i can plug it into the a=v/t formula. I got 4.00m/s2 for the 75 kg object. What am i doing wrong?because i cannot find the answer.
That equation only applies for constant velocity motion, but this is accelerated motion. Hint: Use the average velocity.
but vf-vi still equals 4 doesn't it/
To find the time, use t = d/vave (instead of t = d/v). What's the average velocity?
ok, but is the average velocity not 4?? because vf is 4 and vi is 0...
could i use the formula (vf + vi)/2 to find it? then divide 5m/s2 by 2m/s2 to give me 2.5??
Right--that gives you the average velocity. Then use that to find the time, then the acceleration.
alrite. thanks =D
