Register to reply
Object Weight given only difference in weights in and out of water
by missnola2a
Tags: difference, object, water, weight, weights
Share this thread:
missnola2a
#1
Jul27-09, 12:39 AM
P: 13
A chunk of carbon steel with density, ρ = 7.84 g/cm3 , is completely submerged in fresh water. The chuck of steel weighs 39 N more in air than in water. Please answer the following:
(a) Find the buoyant force acting on the chuck of steel.
N
(b) Find the the volume of the chuck of steel.
m3
(c) What is the mass of the chuck of steel?
2. Relevant equations
Fw(air)=Fw(water) + 39 N
d=m/v
Fb=gp(f)V
BUT I dont know how to find the volume.
density of air is 1.16 kg/m3
density of water is 1.0x10^3
3. The attempt at a solution
once I get the VOLUME I can find the relative weights by using rho*g*v
and Fw(water)+ 39N = Fw(air)
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
Sakha
#2
Jul27-09, 12:45 AM
P: 295
The buoyant force (upward direction) in the air is less than in the water, therefore
Fw(air)=Fw(water) -39 N
And you know that (mg-Fw(air))/g = m
rl.bhat
#3
Jul27-09, 12:46 AM
HW Helper
P: 4,435
Weight of the displaced water = 39 N = m*g = density of water*volume*g.
missnola2a
#4
Jul27-09, 01:04 AM
P: 13
ok, a little hazy. Fw(water) is 39N=dens water*v*g? than V = .00398
if so, Fw(water)-39N=Fw (air) than Fw(air) is /38.96??
missnola2a
#5
Jul27-09, 01:05 AM
P: 13
-38.96 (which cant be right) *rather than /38.96
rl.bhat
#6
Jul27-09, 01:11 AM
HW Helper
P: 4,435
Quote Quote by missnola2a View Post
Fw(in air ) = density of steel*volume*g.
missnola2a
#7
Jul27-09, 01:20 AM
P: 13
OHH,...
so what you are saying is that I use previously acquired volume of .00398 in this eq.
I am sorry if I am frustrating. I mean well!
OH no... do I convert 7.84 g/cm^3 to kg/m^3 ??
if so 7.84 g/cm^3 (100cm*100cm*100cm) * 1kg = 7840 kg/m^3
(1m^3) 1000 G
Fw(air) = 7.84 g/cm3
OR
Fw (air) = 7840 kg/m^3 * .00398 m^3 * 9.81 m/s
is that right?
then to get weight in water I subgract (39N/9.81) ?
rl.bhat
#8
Jul27-09, 01:33 AM
HW Helper
P: 4,435
No.
The weight in water = F(air) - 39 N.
Register to reply
Related Discussions
Block is lowered into water, what is weight of water spilled? Introductory Physics Homework 4
How much does a falling object weights ? Classical Physics 6
Weight of object Introductory Physics Homework 2
Find the magnitude of the difference between the weights (temperature question) Introductory Physics Homework 1
Effective Weight of Falling Object General Physics 2
