Problem on the transfer of heat into different materials
  • Thread starter Thread starter lemonbrook
    Heat Materials
The discussion focuses on estimating the depth at which a temperature of 723K would be reached in a titanium alloy specimen after 3 seconds of immersion in a liquid salt bath at 773K. Key thermal properties are provided: titanium has a thermal conductivity of 6 W m-1 K-1 and a specific heat capacity of 500 J kg-1 K-1. The relevant equation for heat transfer is identified as the rate of heat flow, incorporating thermal conductivity and temperature difference. The thermal diffusivity approach, L2/D, is suggested for estimating the time required for temperature propagation.
  • Understanding of thermal conductivity and its units
  • Familiarity with specific heat capacity and density concepts
  • Knowledge of heat transfer equations and thermal diffusivity
  • Basic algebra for rearranging equations
  • Research the calculation of thermal diffusivity for different materials
  • Learn how to apply the heat transfer equation in practical scenarios
  • Explore the effects of material properties on heat transfer rates
  • Investigate numerical methods for solving heat transfer problems
Students and professionals in materials science, thermal engineering, and physics who are interested in heat transfer analysis and material property applications.
lemonbrook
Hi all,
1. The problem statement
A copper specimen, initially at 293K, is immersed in a bath of liquid salt at 773K. The bath is agitated and the heat transfer at the surface of the metal is effectively perfect. A temperature of 723K is measured at 5mm below the surface of the metal item after 3 seconds. Estimate the depth below the surface at which a temperature of 723K would be reached in 3 seconds if the specimen were made of titanium alloy.
Copper
Thermal Conductivity = 380 W m-1 K-1
Specific Heat Capacity = 390 J kg-1 K-1
Density - 8900 kg m-3
Titanium
Thermal Conductivity = 6 W m-1 K-1
Specific Heat Capacity = 500 J kg-1 K-1
Density - 4500 kg m-3
This equation wasn't given in the question but seems to be relevant.
where
is the rate of heat flow, k is the thermal conductivity, A is the total cross sectional area of conducting surface, ΔT is temperature difference, and x is the thickness of conducting surface separating the 2 temperatures.
I'm very confused as to how to approach this problem. I first attempted to rearrange the equation for Area, but I would also need to have ΔQ which would require a mass to calculate. Could I just use and arbitrary volume for both components and use the density to calculate a mass?
Thanks
Hi lemonbrook, welcome to PF. A common way of estimating the required time for a temperature change to propagate a distance [itex]L[/itex] is [itex]L^2/D[/itex], where [itex]D[/itex] is the material's http://en.wikipedia.org/wiki/Thermal_diffusivity" .
That it!
Thanks very much!
  • · Replies 16 ·
