Ball kinematics in one dimension
The problem involves kinematics, specifically analyzing the motion of a ball thrown upward from a building and determining the average speed of a person running to catch it at the ground level. The scenario includes initial conditions such as the height of the building and the initial speed of the ball.
  • Participants discuss the time it takes for the ball to hit the ground and how that relates to the runner's speed. There are attempts to derive the time using kinematic equations and considerations of the ball's motion both upward and downward.
Some participants have provided guidance on how to approach the problem, including the need to calculate the time for the ball to fall from its peak height to the ground. There is an ongoing exploration of different methods to find the total time and the runner's average speed, with no explicit consensus reached.
Participants question the assumptions regarding the ball's initial downward velocity and the method of calculating total time, indicating a need for clarity on these points. The problem setup includes specific distances and speeds that are critical to the calculations.
Cheddar
A ball is thrown upward from the top of a 25.0-m-tall building with an initial speed of 12m/s.
At the same time, a person is running on the ground at a distance of 31.0m from the building.
What is the person's average speed if he catches the ball at the bottom of the building?
vertical displacement = final velocity(squared) - initial velocity(squared) / (2 * acceleration)
time = final velocity - initial velocity / acceleration
So the first equation gives me the displacement above the building.
Using the 2nd equation I obtained the amount of time it takes to reach that displacement.
I then multiplied that time by 2 for the time up and back down to initial position.
This is as far as I get.
This is known as a "two object catch-up" problem. All catch-up problems in kinematics are solved using the same procedure. Here it is.
1. Write an expression giving the position of object 1 at any time t.
2. Write an expression giving the position of object 2 at any time t.
3. If we denote the catch-up time by tC, the two expressions must be equal when evaluated at tC. Say this with an equation and solve for tC.
4. Once you have tC, you can find anything else the problem is asking using the appropriate kinematic equation(s).
What you are attempting to find is the time for the ball to hit the ground. Once you have that, then you can determine how fast the person on the ground has to run to cover the 31 meters in that amount of time.
What you have so far is the time for the ball to travel up and then back down to the roof height of the building. Now you need add the amount of time for the ball to fall from there to the ground. You know the distance it has to fall since you are given the building height. However, it is not a simple ball drop problem because the ball already has an initial velocity as it passes downward past the building roof top. You need to either recognize or calculate what that initial downward velocity is and then find the time for it to hit the ground.
Alternately, instead of multiplying the time you already found by 2. Just use the time it takes for the ball to travel up and momentarily stop. Use that time to find how height the ball is above the ground. From that point, it is a simple ball drop motion with zero initial velocity. Add the two times to get the total time.
So, the ball hits the ground in 3.793811901 seconds?
31.0 meters/ 3.793811901 seconds = 8.2 m/s (runner's average velocity)?
I would agree with that answer.
You got it.
Thank you both. Very well explained.
  • · Replies 38 ·
  • · Replies 21 ·
