Light-water reactor and plutonium produce
  • Thread starter Thread starter magnetar
    Reactor
Light-water reactors (LWRs) can theoretically produce plutonium from uranium-238, similar to heavy-water reactors. However, the practical feasibility of using LWRs for weapons-grade plutonium production is low due to the formation of Pu-240, which renders the material unsuitable for nuclear weapons. Continuous operation of LWRs for extended periods makes it economically and technically challenging to extract Pu-239. The discussion emphasizes that conventional methods, such as gas centrifuges for uranium enrichment, are more efficient for weapon production than using commercial reactors.
  • Understanding of light-water reactor (LWR) and heavy-water reactor principles
  • Knowledge of plutonium isotopes, specifically Pu-239 and Pu-240
  • Familiarity with nuclear fuel cycles and fission processes
  • Awareness of uranium enrichment techniques, particularly gas centrifuges
  • Research the differences between light-water reactors and heavy-water reactors
  • Study the properties and implications of plutonium isotopes in nuclear applications
  • Explore the uranium enrichment process using gas centrifuges
  • Investigate the economic and technical challenges of plutonium extraction from spent nuclear fuel
Nuclear engineers, policymakers in energy sectors, and individuals interested in nuclear proliferation and reactor technology will benefit from this discussion.
magnetar
In principle, light-water reactor can also produce plutonium from uranium-238 as heavy-water reactor .Plutonium can be used to make nuclear-weapon!
But,Why do we like to offer this kind of power plant to other nations?
LWR's don't just make plutonium in principle. A significant amount of energy produced by commercial LWR's actually does comes from plutonium fission!
While Plutonium-239 is weapons grade, when left in a reactor for more then a few weeks it will absorb another neutron, becoming Pu-240. Pu-240 poisons the fuel as far as weapons are concerned, its presence prevents the material from being used in a weapon.
If you had the technology to separate Pu-240 from Pu-239 then you could have more easily separated U-235 from U-238, which would be far cheaper since the Plutonium isotopes are closer together in mass, and come from radioactive fuel which was in the reactor.
So to answer your question - we aren't worried about other nations being able to make weapons-grade material with LWR's because it really isn't feasible, unless you stop the reactor to refuel it every few weeks instead of running it for 2 years. This kind of activity would not go unnoticed and would be expensive and wasteful compared to conventional methods (e.g. if you had the money to waste on a commercial-sized LWR to operate it with a capacity factor < 50% to refuel it all the time, as well as the fuel processing plant to get the plutonium out of the highly radioactive fuel, you could have afforded a small research reactor to breed plutonium to begin with).
QuantumPion is correct. No one has ever used a commercial reactor to produce Pu-239 for weapons. The easiest route to a weapon doesn't require a reactor at all. You need a source of uranium, such as yellowcake and a gas centrifuge.
http://en.wikipedia.org/wiki/Gas_centrifuge"
Also constructing a nuclear weapon with U-235 is easier than Pu-239.
  • · Replies 0 ·
  • · Replies 30 ·
  • · Replies 0 ·
