Scope of low altitude tank with high pressure simulation.
The discussion revolves around a proposed modification for tanks that allows them to store and release fluid at high pressure, even when situated at low altitudes. Participants explore the potential applications of this technology, including its use in water storage and distribution systems.
  • One participant suggests that the modification could allow tanks to release fluid at high pressure, facilitating water delivery to higher altitudes.
  • Another participant questions the feasibility of storing pressure in a rigid tank, noting that liquids are incompressible and suggesting that balloon-like tanks might be necessary.
  • Some participants propose that the modification could be useful for underground water storage tanks, particularly in areas with irregular water delivery.
  • Concerns are raised about the practicality of storing large amounts of water in tanks for city distribution, with comparisons made to existing municipal water systems.
  • One participant mentions the need for pressurized air or gas in the tank to achieve the desired pressure, likening it to the use of air compressors in existing systems.
  • A participant claims to have created a prototype but does not provide sufficient details for others to understand its functionality or application.
  • There is skepticism regarding the proposed technology's application and effectiveness, with some participants expressing doubt about its viability and potential marketability.
Participants express a range of opinions, with no consensus on the feasibility or application of the proposed tank modification. Some see potential uses, while others are skeptical and question the underlying principles.
Participants highlight the need for more detailed explanations of the technology and its workings. There are unresolved questions about the practicality of the proposed system and its adherence to established hydraulic principles.
dE_logics
Suppose a company has developed a modification for almost all types of tanks such that when the tank is filled with an incoming fluid (which is at a certain pressure), it stores this pressure and uses it to take the fluid out of the tank with pressure, i.e even if the tank is at low altitude it will give out the fluid at a high pressure (maximum pressure will be equal to the input pressure) such that it can easily reach higher heights (or, apparently the places where the fluid needs to be supplied with pressure).
This modification will be extremely cheep (negligible consideration of price).
Another advantage can be that even if the input pressure is low, the tank can be modified (in real time) to accommodate that low pressured fluid, and after the tank has been filled, pressure in the tank can be increased manually or by a low powered motor till the desired amount to suffice requirements. The motor will be turned off after a desired pressure has been reached.
So...what will be the scope of such a modification (globally) if the company starts selling such units (or at most, some personnel will come and set it for you) to modify any given tank as stated above?
For example, water storage tanks can be put to lower altitudes or even underground, yet water will be directly send from this tank to multi-storied buildings/houses.
Liquids are not compressible, so you can't store the pressure in a rigid tank. Perhaps you could make tanks that are like balloons, but if you do something like that, you're making the pump less efficient and making it take longer to fill.
I don't really see anything useful here, but perhaps I'm missing something - could you give me a more specific scenario where it would be useful?
The efficiency and all...the procedures of how it's to be done is...aaa...not the exact question here...it's strictly the scope of such a thing.
It can be used in city water tanks...they can be made underground.
At places where water delivery is irregular, this can be useful to store water at a pressure.
These are 2.
Cities consume far too much water for it to be stored in tanks for distribution - no such thing exists. The closest parallel may be small municipal water towers. For places where water delivery is irreglar and would be stored in tanks (this is done in Mexico, it is stored in tanks on peoples' roofs), storing it on the roof provides the pressure needed to distribute it through the house.
Something cheap, that can be put on any tank, and stores pressure - well, you can use a check valve and close the vent on the tank, if it has one. Of course, you're also assuming the tanks are rated to hold pressure (ie, you wouldn't want to do this with a gas tank on a car). If you do that, you can store the air in the tank to pressurize it, but that reduces the capacity of the tank and the pressure would be variable anyway - so not terribly useful. And if you let the air out and then pressurize it with the water itself, once you let a tiny amount of water out, all of the pressure is gone.
It sounds like you don't want to tell me because you think you've invented something and want to sell it. I suspect you misunderstand the principles of hydraulics and have invented nothing. No offense, but you do that kind of thing a lot.
If I were wanting to be an inventor and were having such problems, I'd probably try to fix it by taking some physics or engineering courses in the discipline I'm trying to invent in.
Well...I made a prototype.
All water consumed at near constant pressure (the weight of water makes the pressure vary by a small amount).
No defying laws this time :-p :smile:
It was really stupid of me to make the last one...I usually don't do that.
So, you mean it has a bit of scope?
One would need pressurized air (or other gas) in the tank to do this. Seems like a simple air compressor, with a hose leading into the water tank. Well, perhaps a very large air compressor, if the goal is to supply water to a tall building.
I suspect this is already done ... now that I think about it, I think my mom's house does use an air compressor to push the well water through the pipes.
Well that's nice, but your description so far isn't anywhere near detailed enough to know what you've made a prototype of.
And when you say "prototype", you mean you have it installed somewhere and functioning? What is it doing (what is it installed on)?
I don't know what you mean by "scope". It has no application that I can think of, but then that may just be because I don't see how it could possibly work. But that's your catch-22, not mine: in order to commercialize something, you first have to be able to explain to people what it does, how it does it and why.
There's a similar thread in another forum asking why thc patches don't exist...
The documentation.
I've applied a patent before...apparently the documentation and all is completely pending...gotta make that.
The major problem here is exactly which company should I contact?
No, it does not use compressors and all.
I am in the dark too. To me it sounds like a well tank or a hydraulic accumulator that has a charging pump attached to it. Definitely more details are needed to steal...er...I mean understand this thing.
  • · Replies 17 ·
