D/dx |x+2|^x (solution known, need explanation)
  • Thread starter Thread starter Dafydd
    Explanation
The discussion revolves around finding the derivative of the function |x+2|^x, with participants seeking clarification on the reasoning behind the solution provided. The subject area includes calculus, specifically the differentiation of functions involving absolute values and exponentials.
  • Participants discuss the application of derivative formulas, particularly the chain rule and the treatment of absolute values. There is an exploration of the implications of differentiating an expression where the base is dependent on the variable.
The discussion has progressed with participants providing insights and corrections regarding the application of differentiation rules. Some have offered alternative methods of approaching the problem, such as considering cases based on the sign of the expression inside the absolute value. There is an acknowledgment of the complexity involved in remembering various differentiation techniques.
Participants note that the problem may have been derived from an exam context, which could impose specific constraints on how the solution is approached, particularly regarding the treatment of absolute values and potential undefined points.
Dafydd
Solved! d/dx |x+2|^x
I need someone to explain this:
http://www.dafydd.se/stuff/solvethis.png
I guess the following are of relevance...
[tex]\frac{d}{dx} |x| = \frac{x}{|x|}[/tex]
[tex]\frac{d}{dx} a^x = a^x ln a[/tex]
The solution is up there. I just need help understanding why this is the solution.
Normally, iirc a derivative of an expression is the outer derivative times the inner derivative, but here it seems to be the original expression times the inner plus the outer derivative, or something in between... eh.
Your formula for the derivative of the exponent does not apply here. Note that the a in your formula is a constant, where as the 'a' in this problem is x dependent.
Realise that:
[tex] |x+2|^x=e^{\log|x+2|^x}=e^{x \log|x+2|}[/tex]
Can you take it from here?
Hm.
[tex] \frac{d}{dx} e^x = e^x \frac{d}{dx} x[/tex]
and
[tex] \frac{d}{dx} ln|x| = \frac{1}{x}[/tex]
so
[tex] \frac{d}{dx} e^{x \log|x+2|} = e^{x \log|x+2|} \frac{d}{dx}(x \log|x+2|) = e^{x \log|x+2|} (ln|x+2| + \frac{x}{x+2}) = |x+2|^x (ln|x+2| + \frac{x}{x+2})[/tex]
Thanks for the tip, I would never have thought of that. There's too many "tricks" to remember.
What you wrote in the last line of your post is correct, I have just a small comment on the notation in the first formula: actually
[tex] \frac{d}{dx} e^x = e^x.[/tex]
What you meant was
[tex] \frac{d}{dx} e^{f(x)} = e^{f(x)} \frac{d}{dx} f(x)[/tex]
which is a consequence of the chain rule. It is this you are using (for f(x) = x log|x + 2|).
You applied it correctly though.
Ok, yes, you're right. Thanks!
Not that it matters that much to me right now, but how is it a consequence of the chain rule?
If we have a composite function f(g(x)) then the chain rule says that:
[tex] \frac{df(g(x))}{dx}=\frac{df}{dg}\frac{dg}{dx}=f'(g(x))g'(x)[/tex]
The same happens with the exponent where [itex]f(x)=e^x[/itex], [itex]g(x)=x \log|x+2|[/itex] and [itex]f(g(x))=\exp(x \log|x+2|)[/itex]. This is the chain rule.
Instead of trying to do derivative formulas with absolute values in them, it may be better to take two cases, x+2 > 0 and x+2 < 0 ... also note that the answer is undefined when x+2 = 0 anyway.
Cyosis - got it, thanks!
g_edgar - I agree, but the example was taken from an old exam and what I wrote in the first post was the only answer or explanation given in the solutions. I don't know if a solution taking two cases would have given full credit.
  • · Replies 105 ·
13K
  • · Replies 25 ·
  • · Replies 24 ·
  • · Replies 54 ·
19K
