Path Integral Propagator Normalization in Lewis Ryder's QFT book
The thread discusses the normalization of the path integral propagator as presented in Lewis Ryder's Quantum Field Theory book, particularly focusing on the implications of the normalization factor \( N \) and its behavior as the discrete time interval approaches zero. The discussion encompasses theoretical aspects of quantum mechanics and path integrals.
  • One participant questions whether \( N \) can be identified as \( \left(\frac{m}{i\hbar\tau}\right)^{(n+1)/2} \) and seeks clarification on the meaning of "normalized transition amplitudes."
  • Another participant suggests that the normalization means that the squared amplitude summed over all final states equals one, implying that \( N \) becomes irrelevant as it can be factored out.
  • Concerns are raised about the implications of \( N \) going to infinity and how this affects the probability interpretation of the amplitudes.
  • A participant compares the normalization process to a lottery analogy, suggesting that while the number of wins increases, the overall probability must still be normalized.
  • There is a discussion about the normalization factor \( N \) potentially canceling out when comparing to the free particle propagator.
  • One participant introduces the concept of saddle point approximations and their relevance to path integrals, particularly in the context of harmonic oscillators.
  • Another participant proposes a different expression for \( N \), indicating a potential misunderstanding or correction regarding its formulation.
Participants express differing views on the nature of the normalization factor \( N \) and its implications for the path integral. There is no consensus on the exact formulation of \( N \) or its role in the normalization process, indicating that the discussion remains unresolved.
Participants note potential typographical errors in the original formulation of the Lagrangian and the path integral, which may affect the interpretation of the normalization process. There are also mentions of divergences in the context of path integrals that complicate the normalization discussion.
This discussion may be of interest to students and researchers in quantum mechanics, particularly those studying path integrals and quantum field theory, as well as those exploring the mathematical foundations of normalization in quantum amplitudes.
maverick280857
Hi,
In Lewis Ryder's QFT book on page 160, the propagator for the case when the Lagrangian can be written as
[tex]L = \frac{p^2}{2m} + V(q)[/tex]
is given as
[tex]\langle q_f t_f|q_i t_i \rangle = \lim_{n\rightarrow\infty}\left(\frac{m}{i\hbar\tau}\right)^{(n+1)/2}\int \Pi_{1}^{n}dq_{j}\exp{\left\{\frac{i\tau}{\hbar}\sum_{0}^{n}\left[\frac{m}{2}\left(\frac{q_{j+1}-q_{j}}{2}\right)^{2}-V\right]\right\}}[/tex]
and hence in the "continuum limit" as
[tex]\langle q_f t_f|q_i t_i \rangle = N\int\mathcal{D}q\exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L(q,\dot{q}) dt\right]}[/tex]
To quote the author,
In the limit [itex]n\rightarrow\infty[/itex], [itex]N[/itex] becomes infinite, but this does not matter, since we shall always deal with normalised transition amplitudes.
Now, I'm guessing [itex]N = \left(\frac{m}{i\hbar\tau}\right)^{(n+1)/2}[/itex]. Am I right? Also, what does he mean by "we shall always deal with the normalized transition amplitudes"? What is the normalization here?
Thanks in advance.
PS -- How does one get the nice looking caligraphic D for the functional integral? I used \mathcal{D}, but the effect isn't as pronounced as in Ryder's book :-P
The 2 in the denominator inside the squared-velocity should probably be a tau, and the Lagrangian should probably have minus the potential in it, and not positive the potential.
You're right about 'N'. It goes to infinity as tau, the discrete time interval, goes to zero. Normalization means that [tex] | \langle q_f t_f|q_i t_i \rangle |^2[/tex]
summed over all final states [tex]|q_f,t_f>[/tex] equals one, since at time [tex]t_f[/tex] the particle has to be in some [tex]q_f[/tex]. So the N doesn't really matter since you multiply every amplitude by the same constant factor to get the total probability of being somewhere add up to one.
Thanks for the reply, RedX.
Yes, you're right. Typographical mistake, sorry about that.
Ok, but then
[tex]|\langle q_f t_f|q_i t_i\rangle|^2[/tex]
is proportional to [itex]N^2[/itex], and if you sum it over all possible final states [itex]|q_f t_f\rangle[/itex], you will get a sum multiplied by [itex]N^2[/itex]. If this sum is to become one even as [itex]N \rightarrow \infty[/itex] shouldn't the sum it multiplies tend to zero or something?
I am using
[tex]\langle q_f t_f|q_i t_i\rangle = N \int \mathcal{D}q \exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L(q,\dot{q}) dt\right]}[/tex]
to make this assertion.
I'm not entirely sure I understand how something as simple as [tex] \langle q_f t_f|q_i t_i\rangle[/tex]
happens to be infinity. My guess is that in order to derive the path integral, one inserts too many intermediate states in between the initial and final states (using the completeness relations) and that's where the infinity comes from.
Nevertheless, I would view this normalization as similar to playing the lottery. The more times you play, the more times you win. However, this should not affect the probability. So if you win the lottery 10 times, you have to divide by the 100 times you played, for a 10% winning probability. Similarly, I would view what you're calculating as not the probability, but how many times you've won, or how many times the particle is found at [tex]q_f[/tex]. So what you have is relative probabilities - you can tell that one state is 3 times more likely if you win with that state 3 times more. To get the absolute probability, you have to divide by an overall constant to get everything to add up to 1.
Ok, my first thought was that in normalizing the amplitude, the N is cancelled.
Anyway since the author claims there is no problem, N is really going away right?
(PS -- Sorry if this is a trivial question, but I couldn't see how the normalization worked.)
Any ideas?
Well, I'm not sure I can answer your question the way you would like it but I think you should always think of the right hand side of
[tex] \langle q_f t_f|q_i t_i\rangle = N \int \mathcal{D}q \exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L(q,\dot{q}) dt\right]}[/tex]
as a "short hand notation" for the discretized form. In the case of a free particle ([itex]V=0[/itex]) you can check by explicit calculation of the discretized form that it is finite and indeed gives you the correct form of the propagator using [itex](n+1)\tau=t_f-t_i[/itex]. When evaluating path integrals for [itex]V\neq 0[/itex], one usually uses the free propagator as a "comparison"/normalization to obtain the correct form. For example:
[tex] \langle q_f t_f|q_i t_i\rangle = N \int \mathcal{D}q \exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L(q,\dot{q}) dt\right]}=\frac{N \int \mathcal{D}q \exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L(q,\dot{q}) dt\right]}}{\langle q_f t_f|q_i t_i\rangle_0}\langle q_f t_f|q_i t_i\rangle_0[/tex]
where [itex]\langle q_f t_f|q_i t_i\rangle_0[/itex] denotes the propagator of a free particle. Then inserting in the denominator the path integral expression for the free particle you find that the "normaliziation factor" [itex]N[/itex] cancels.
[tex] \langle q_f t_f|q_i t_i\rangle = N \int \mathcal{D}q \exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L(q,\dot{q}) dt\right]}=\frac{ \int \mathcal{D}q \exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L(q,\dot{q}) dt\right]}}{\int \mathcal{D}q \exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L^0(q,\dot{q}) dt\right]}}\langle q_f t_f|q_i t_i\rangle_0[/tex]
where [itex]L^0=m\dot{q}^2/2[/itex], i.e. the Lagrangian of a free particle. Then finally you can replace [itex]\langle q_f t_f|q_i t_i\rangle_0[/itex] with the explicit form of the free particle propagator. This way we don't have to deal with the factor [itex]N[/itex].
Thanks jensa and RedX, I think I have a better understanding of this now. I'll use this thread if I have any more queries regarding the normalization.
Maverick,
Just wanted to add something on top of what I said before. Since almost all we can do with path integrals boils down to some combination of perturbation expansion, saddlepoint approximations and gaussian integrals it is useful to look at the case with quadratic potential [itex]V(q)=m\omega_0^2q^2/2[/itex], i.e. Harmonic oscillator. A saddle point approximation of such an action including gaussian fluctuations around the classical path turns out to be exact. You can then expand the fluctuations in as [itex]\delta q=\sum_n c_n \sin(\omega_n x)[/itex] where [itex]\omega_n=\pi n/(t_f-t_i)[/itex]. Eventually you get something like this
[tex] \int \mathcal{D}q \exp{\left[\frac{i}{\hbar}\int_{t_i}^{t_f}L(q,\dot{q}) dt\right]}\propto e^{S[q_c]}\frac{1}{\sqrt{\textrm{det}[-(\partial_t^2+\omega_0^2)]}}=e^{iS[q_c]}\frac{1}{\sqrt{\Pi_{n=1}^{\infty} (\omega_n^2-\omega_0^2)}}[/tex]
Notice that since the infinite product is divergent this path integral goes to zero. I guess what eventually gives you a nonzero answer is that the normalization factor [itex]N[/itex] becomes infinite, but there is no way to compare the two divergencies. This is why its easier to evaluate the quotient of two path integrals such that the normalization factor N cancels and you will need to evaluate a quotient of determinants which is not divergent:
[tex]\frac{\textrm{det}[-(\partial_t^2+\omega_0^2)]}{\textrm{det}[-\partial_t^2]}=\Pi_n\frac{\omega_n^2-\omega_0^2}{\omega_n^2}[/tex]
Thanks jensa.
By the way, I worked out the math for myself, and I think
[tex]N = \left(\frac{m}{ih\tau}\right)^{n(n+1)/2}[/tex]
instead of
[tex]N = \left(\frac{m}{ih\tau}\right)^{(n+1)/2}[/tex]
This is because
[tex] \int \Pi_{j=0}^{n}\frac{dp_j}{h}\exp{\left(\frac{i\tau}{\hbar}\sum_{j=0}^{n}\left[\frac{p_{j}(q_{j+1}-q_{j})}{\tau}-\frac{p_{j}^2}{2m}-V(q_{j,avg})\right]\right)} = \left(\frac{m}{ih\tau}\right)^{(n+1)/2}\exp\left\{\frac{i\tau}{\hbar}\sum_{j=0}^{n}\left[\frac{m}{2}\left(\frac{q_{j+1}-q_{j}}{2}\right)^2 - V\right]\right\}[/tex]
So the second integral [itex]\int \Pi_{j=0}^{n}dq_{j}\ldots[/itex] should give rise to the extra factor of n in the exponent.
Can someone please confirm whether my math is correct, because this would mean that there is a misprint in the book.
Thanks in advance.
  • · Replies 19 ·
