Trouble determining the correct direction errors for nullclines
  • Context: Graduate
  • Thread starter Thread starter abacus
    Direction Errors
The discussion revolves around determining the correct direction errors for nullclines in a system of differential equations. Participants explore how to analyze the direction of movement along the nullclines and the appropriate equations to use for this analysis.
  • Exploratory, Technical explanation, Debate/contested
  • One participant presents a system of equations and expresses confusion about how to determine the direction of movement along the nullclines.
  • Another participant suggests calculating the slope by dividing (dy/dt)/(dx/dt) at a given point to understand the direction away from the nullclines.
  • A later reply questions the clarity of the previous suggestion, indicating uncertainty about which equations to use for specific sample points to determine direction.
  • There is a challenge regarding whether the slope calculation provides the necessary information to determine direction along the nullclines.
The discussion remains unresolved, with participants expressing different levels of understanding and clarity regarding the appropriate methods for determining direction along the nullclines.
Participants have not reached a consensus on the specific equations to use for evaluating direction at sample points along the nullclines, leading to ongoing confusion and uncertainty.
abacus
I have a simple question regarding nullclines, as I'm having trouble determining the correct direction errors.
For example, here's a system of equations:
dx/dt = 2-x-y
dy/dt=y-x^2
x-null is y= -x + 2
y-null is y= x^2
x-null is vertical, y-null goes horizontal.
But when I divide the graph in different sections, and pick different plot points which equations do I plug into to find directions?
I know that wasn't clear, but for example:
If I want to know if on the y-null if the direction of a certain section is pointing left or right, would I plug the points I chose in:
A) dy/dt = y-X^2
B) dx/dt=2-x-y
or C) y=x^2
I'm not sure which equation to plug it in. I've tried to think it out, but I end up always confusing myself. Please point me in the right direction. Thanks.
If I understand correctly what you are doing, away from the "null clines" (pointswhere they intersect are equilibrium points) you would calculate dx/dt and dy/dt at the point then divide (dy/dt)/(dx/dt) to get the slope.
I'm not sure if that quite helps, I want to know when I take some sample points, which equations do I plug them into in order to get the correct direction.
If that is not given by the slope, (dy/dt)/(dx/dt) then I don't know what you want.
  • · Replies 16 ·
  • · Replies 65 ·
10K
  • · Replies 18 ·
