What is the effect of charge and distance on electric potential energy?
The discussion revolves around the effect of charge and distance on electric potential energy, specifically in a scenario involving point charges placed at the corners of a square. The original poster presents a problem involving the calculation of electric potential differences and changes in potential energy as a charge is moved between two points.
  • Participants explore the relationship between electric potential and charge, questioning the implications of charge placement and distance. There are attempts to calculate potential differences and potential energy changes, with some participants expressing uncertainty about the problem's requirements and the correctness of their calculations.
The discussion includes various attempts to clarify the problem and verify calculations. Some participants have provided guidance on how to approach the calculations, while others are still grappling with the interpretation of the problem and the implications of their findings.
There is some confusion regarding the placement of charges and the distances involved, which may affect the calculations. Participants are also navigating the challenge of understanding the relationship between electric potential and potential energy in the context of the problem.
nugget
A, B, C and D are corners of a square in empty space, sides 12 micrometres, charges +5nC and -5nC are placed at corners A and B respectively.
What is the change in the electric potential from D to C? (take care with sign)
A third charge of -2nC is initially at D then moved to C, what is the change in the potential energy of the system? (take care with sign)
not sure, something linking distance and charge
if the charges are in space, there is no conduction of charge so at D and C wouldn't you expect there to be no electric potential?
Please look up in your textbook the equation for the "electric potential due to a point charge". That equation is very relevant as a starting point for this problem.
I think i have figured out the first answer;
I got + 2.2x106 Volts for the difference between D and C. I'm not sure if this number is way too large but I wouldn't be surprised seeing as charges were given in nanocoulombs and distances are in micrometers.
now I am unsure what the second half of the question is asking - when it says 'change in potential energy of the system,' does that mean i should put a test charge in the centre and then add the third charge, measure potential, then move the third charge and measure again?
I checked your number and it is correct assuming that points A and C are diagonally across from each other.
For the next part what you are asked to do is
1. Calculate the total potential energy Uinitial with the first two charges where they are and the third charge at point D.
2. Calculate the total potential energy Ufinal with the first two charges where they are and the third charge at point C.
3. Calculate the difference Ufinal - Uinitial
This seemingly three-step problem can be done in one step (and that's the point of this part) if you remember that the potential energy of a charge q is U = q V, where V is the electrostatic potential at the location of the charge.
Can you put it together now?
unfortunately A and C are not diagonally opposite, but rather A is top left, B top right and C is bottom left, i.e. D bottom right. is my answer still correct?
When you say calculate Uinitial, do i need to work out V at A, B and D before i can calculate qV?
You have already calculated V at A and V at B in the first part. That is why you can do it in one step. All you need to do to find Uinitial is to multiply the third charge by V at A. Same thing for Ufinal.
you would have a new distance I believe. B would be further away from C than what was given... hypot of a right triangle (root 2 multiplied by what was given...) If I am seeing this correctly
whoops it may not matter based on what was asked..
  • · Replies 23 ·
  • · Replies 22 ·
