Compound contains only carbon, hydrogen, nitrogen, and oxygen.
The empirical formula of a compound containing only carbon, hydrogen, nitrogen, and oxygen can be determined through combustion analysis and nitrogen analysis. In the discussed experiments, 0.157 g of the compound produced 0.213 g of CO2 and 0.0310 g of H2O, while 0.103 g of the compound yielded 0.0230 g of NH3. The carbon and hydrogen percentages can be calculated from the combustion products, while the nitrogen percentage is derived from the ammonia produced. The total percentages of C, H, and N will not sum to 100%, indicating the presence of oxygen in the compound.
  • Understanding of combustion analysis and its applications in empirical formula determination.
  • Knowledge of stoichiometry and how to convert mass of products to moles.
  • Familiarity with the Kjeldaahl method for nitrogen analysis.
  • Basic skills in calculating percentage composition from experimental data.
  • Study the principles of combustion analysis for empirical formula determination.
  • Learn how to perform stoichiometric calculations involving gases and their products.
  • Research the Kjeldaahl method for nitrogen quantification in organic compounds.
  • Explore how to calculate the percentage composition of compounds from experimental data.
Chemistry students, educators, and researchers involved in organic chemistry and analytical chemistry, particularly those focused on empirical formula determination and combustion analysis.
Kathy Chan
A compound contains only carbon, hydrogen, nitrogen, and oxygen. Combustion of 0.157 g of the compound produced 0.213 g CO2 and 0.0310 g H2O. In another experiment, it is found that 0.103 g of the compound produces 0.0230 g NH3. What is the empirical formula of the compound? Hint: Combustion involves reacting with excess O2. Assume that all the carbon ends up in CO2 and all the hydrogen ends up in H2O. Also assume that all the nitrogen ends up in the Nh3 in the second experiment.
What I have is
___+ O2 --> CO2 + H2O
___-->NH3
I got stuck after this. I wonder how a compound that contains C, H, N and O yields only NH3. where did C and O go?
Please help me. Thank you so much
There are two experiments. In one experiment you determine the amount of C and H for a given sample size. This can be expressed in percentage. For example 4.4 g CO2 in the first experiment can be expressed as 1.2 g C (elemental). If the original sample that was analyzed in that experiment was 10 g, you have a sample that is composed of 12% C (1.2g/10g*100). Same applies to the hydrogen and the ammonia determined in the second reaction. Once you have those quantities expressed in percentages, add them together. They should sum to 100%... or should they?
You will find that they won't.
What is missing? Why couldn't "it" (that which is missing) be determined in a combustion experiment or the Nitrogen analysis (probably a keldahl analysis)?
The question did not specify that NH3 is the only product; that is clearly impossible. All that it mentioned was that a certain amount of NH3 was produced (along with other product(s))
9K
11K
18K
