Creating a Computer Flight Model: Best Starting Place for Aerodynamic Theory
  • Context: Graduate
  • Thread starter Thread starter metiscus
The discussion revolves around creating a simple flight simulator focused on subsonic aerodynamics, particularly for a Cessna-like aircraft. Participants explore various aspects of aerodynamic theory, including airfoil data, modeling techniques, and the complexities involved in simulating all six degrees of freedom (6DOF). The conversation includes suggestions for resources and tools, as well as considerations for environmental factors affecting flight dynamics.
  • One participant expresses a desire to learn about subsonic aerodynamics and seeks guidance on the best starting point for aerodynamic theory, mentioning familiarity with NACA reports and airfoil data.
  • Another participant suggests using FlightGear, an open-source flight simulator, which allows for detailed performance modeling through plugins.
  • A third participant mentions a Java application that serves as a calculator for aerodynamics, allowing users to manipulate variables like angle of attack and airspeed to observe lift forces.
  • One participant warns that creating a realistic 6DOF simulator is complex and requires more than just airfoil data, emphasizing the need for stability and control derivatives from wind tunnel or flight test data.
  • Another participant highlights the importance of incorporating various environmental factors, such as weather conditions and altitude-related changes, into the flight simulation model.
  • There is a suggestion that many existing simulators, including Microsoft Flight Simulator and FlightGear, rely on linearized models that may not accurately represent the complexities of flight dynamics.
Participants express differing views on the feasibility and complexity of creating a realistic flight simulator. While some provide resources and suggestions for starting points, others caution about the challenges involved in accurately modeling all aspects of flight dynamics, indicating that no consensus exists on the best approach or methodology.
Participants note the limitations of using airfoil data alone for comprehensive flight modeling and emphasize the need for additional parameters and models to achieve realistic simulations. There is also mention of the dependency on environmental variables that affect flight performance.
metiscus
Lately I've been playing around with the idea of creating a very simple flight simulator as a hobby, just to learn the mathematics behind subsonic (think cessna) aerodynamics. I'm a computer engineer by training, so I am not afraid of mathematics but my current exposure to the dynamics portions of this topic is limited. I have archived and read a large number of the NACA reports from the 1940s and I have a book that contains dozens of the NACA airfoils along with the tabulated curve information. I've got a pdf copy of the DATCOM as well as Andersons book on aerodynamics. I have a very good understanding of 3d mathematics, at least as it applies to computer graphics.
So my question is, what is the best starting place to create such a toy program as far as the aerodynamic theory goes?
I would like to make utilization of actual airfoil data, and have my simulation be semi-realistic. I've started reading up on thin-airfoil theory but there is also the method of using panels. Effectively, if someone could take a few minutes of their time to direct my efforts to a theory of flight that suits my mathematical / physical capabilities, I would be thankful. Please note that I want to model all 6 degrees of freedom, a simple 2d lift-drag wing model is not really what I am looking for. I know that body aero forces are important too, so bonus points if you can give me ideas on how to deal with those as well..
Science news on Phys.org
http://www.flightgear.org/ is an open source flight simulator, IIRC you can write plugins to model the aerodynamics of particular aircraft, a lot of the users are heavily into extremely detailed performance modeling rather than the pretty pictures
I'm not sure if this program is too elementary for what you are trying to do but basically its a calculator for aerodynamics. This program is a java application and it allows you to select from a variety of airfoils and you can change the angle of attack and airspeed to determine the net force of lift. You might consider checking it out:
http://www.grc.nasa.gov/WWW/K-12/airplane/foil2.html"
-James
I just recently made a 6DOF on a cessna 172 for NASA. I'll just say you are in for more than you think, and that you cannot use airfoil data for an entire airplane.
If all you want to do is have basic fun, buy Microsoft Flight Simulator or download Flightgear. If you want a realistic simulator, look elsewhere (i.e. design your own).
To do a full 6DOF requires a substantial amount of work. (People have PhD's in doing 6DOF)
What you need are the stability & control derivatives from wind tunnel and/or flight test data for anything remotely serious. Most simulators like Flight Gear or Microsoft use linearized models about a single trim condition (which is crap).
Hi Metiscus
Please remember all the other variables if you are going to develop a flight sim. You'll need a decent weather and wind modeller. Understand the relationships between altitude, temperature, pressure, true airspeed, indicated airspeed, ground speed, and performance of engines etc.
If you were in the tropics, and the temperature on the ground was 100 F, what do you expect the temperature would be at 10000 feet? And what would be the dew point?
Answer: around 50 F @ 10000 ft, dewpoint around 26 F in fine weather, ratio between IAS and TAS roughly around 1.2 for a cessna
If you are flying in freezing conditions, how long would it take for the "boot" to freeze up if you forgot to hit the anti freeze switch?
You'll need to program all that in.
LeonStanley said:
Hi Metiscus
All that is just fancy garnish. The heart of what you want is the aerodynamic stability and control parameters along with a good engine model. That is where MSFS and flightgear fail miserably.
  • · Replies 42 ·
9K
