Calculating Number of Air Bubbles Needed for Sphere to Float in Water
The problem involves determining the minimum number of air bubbles required for a sphere to float in water, considering the sphere's mass and volume, the volume of the bubbles, and the density of water. The discussion revolves around applying principles of buoyancy and Archimedes's Principle.
  • Participants explore the relationship between the density of the water, the mass of the sphere, and the volume of the air bubbles. There are attempts to derive inequalities for the number of bubbles needed for the sphere to float, with some questioning the assumptions made regarding density and buoyancy.
Some participants have provided insights based on Archimedes's Principle, suggesting that the weight of the displaced water must equal the weight of the sphere plus the weight of the bubbles. Multiple interpretations of the inequalities for the number of bubbles are being discussed, with no explicit consensus reached on the correct answer.
Participants are considering the implications of using whole numbers for the number of bubbles, which affects the interpretation of the inequalities derived from the problem statement.
leena19
Water in a tank is uniformly bubbled with small identical air bubbles each having volume V0.
A sphere of mass M and volume V floats in water due to the attachment of certain number of air bubbles in the surface.If dw is the density of water,and the minimum number of air bubbles that is needed to be attached to keep the sphere floating in water is n, then
(1) n =( M-Vdw)/ (V0dw )
(2) n > ( M-Vdw)/ (V0dw )
(3) n < ( M-Vdw)/ (V0dw)
(4) n > ( V0dw )/( M-Vdw)
(5) n < ( V0dw )/( M-Vdw)
For the sphere to float,the density of water+ air bubble mixture should be more than the density of the sphere (I think?).
Assuming it is so,
dw + n/v0 > M/V
n/v0 > M/V - dw
I get
n > [ (M - dw*V)/V ] * V0
which is not among the choices given
so I hope someone can tell me where I'm going wrong.
Thank you.
Hi leena19,
Never mind the density relation. Go back to basics, namely Archimedes's Principle. For the mass to float, the displaced water must have weight equal to the weight of the object. Here there are two kinds of displaced water: (1) water displaced by the floating mass (we assume that it barely floats, i.e. its entire volume is under water) and (2) water displaced by n bubbles attached underneath the object.
Can you finish it now?
OK I think I get it now,
Mg = (V + nV0)dw*g
therefore n =( M - Vdw) / V0dw
which would be answer no.(1) ?
I would say the answer is (2). Let's say you are given numbers and you substitute and you get 156.6. Since bubbles come in whole numbers, the correct answer would be 157. With 156 bubbles the object would sink. So the > sign ensures that this does not happen.
Alright.
Thank you very much!
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 37 ·
