Vector form of position, velocity, acceleration, and force
The discussion revolves around a physics problem involving vector forms of position, velocity, acceleration, and force, specifically applying Newton's Second Law. The original poster presents a vector function for position and asks for the velocity, mass, and acceleration at specific time intervals.
  • Mixed
  • Participants explore the calculation of velocity and acceleration from the given position vector, questioning the consistency of the results with Newton's Second Law.
  • Some participants express confusion regarding the implications of the vector equation F = ma, particularly in relation to the components of force and acceleration.
  • There are inquiries about the possibility of having different dependencies on time for the components of velocity and acceleration.
The discussion includes attempts to clarify the relationships between force, mass, and acceleration, with some participants suggesting that the problem may be flawed due to inconsistencies in the application of Newton's Second Law. There is acknowledgment of differing interpretations and ongoing exploration of the concepts involved.
Participants note potential over-constraining of the problem and question whether the assumptions made about the forces and accelerations are valid. There is also mention of the lack of clarity regarding whether the given force is the net force acting on the mass.
songoku
[tex]x=\left(\begin{array}{cc}\frac{3}{5}t^2+2t\\10t^2+1\end{array}\right) , 0\leq t \leq 5 \; \text {and} \; F=\left(\begin{array}{cc}3\\1\end{array}\right)[/tex]
a. find v in vector form
b. find mass
c. when t = 5, there is addition of [tex]F=\left(\begin{array}{cc}t\\0\end{array}\right)[/tex]. Find the acceleration when t = 6
d. find v when t = 6
F = ma
a. [tex]v=\left(\begin{array}{cc}\frac{6}{5}t+2\\20t\end{array}\right)[/tex]b. [tex]|F|=\sqrt{3^2+1^2}=\sqrt{10}[/tex]
[tex]a=\left(\begin{array}{cc}\ 6/5 \\20\end{array}\right)[/tex]
[tex]|a|=\sqrt{\left(\frac{6}{5}\right)^2+20^2}\approx 20.04[/tex]
[tex]m=\frac{|F|}{|a|}=\frac{\sqrt{10}}{20.04}\approx 0.158\; kg[/tex]c. [tex]F \; \text{total}=\left(\begin{array}{cc}3\\1\end{array}\right)+\left(\begin{array}{cc}t\\0\end{array}\right) = \left(\begin{array}{cc}3\\1\end{array}\right)+\left(\begin{array}{cc}6\\0\end{array}\right)=\left(\begin{array}{cc}9\\1\end{array}\right)[/tex]
[tex]|F \; \text{total}|=\sqrt{9^2+1^2}=\sqrt{82}[/tex]
[tex]|a|=\frac{|F|}{m}\approx 57.31 \;ms^{-2}[/tex]d. [tex]v=\left(\begin{array}{cc}46/5\\120\end{array}\right)[/tex]
[tex]|v|=\sqrt{\left(\frac{46}{5}\right)^2+120^2}\approx 120.35 \;ms^{-1}[/tex]Do I get it right ?
Thx
yep looks correct to me.
This problem troubles me. Newton's Second Law is a vector equation
F = ma and implies that
Fx=max and Fy=may
from which we get that
m = Fx/ax = Fy/ay
I agree that a = (6/5, 20) so if F = (3, 1), this simply doesn't work.
Thx rock.freak667
Another question : Is it possible if
[tex]x=\left(\begin{array}{cc}\frac{3}{5}t\\10t^2+ 1\end{array}\right)[/tex]
So, the velocity :
[tex]v=\left(\begin{array}{cc}\frac{3}{5}\\20t\end{array}\right)[/tex]
i.e. the velocity is constant in x-direction and depends on t in y-direction?
I think it's possible such in projectile motion, where the velocity in x-direction is constant and changing in y-direction. But I'm not sure...
Thx :)
EDIT :
Sorry, I just read kuruman's post. Yes that makes sense and now I'm confused...or maybe F = ma doesn't imply that Fx=max and Fy=may ? (just guessing)
You are correct. It is entirely possible to have one component depend on time and not the other. As you say, this is the case with projectile motion
[tex] v = \left(\begin{array}{cc}v_{0x}\\v_{0y}-gt\end{array}\right).[/tex]
F = ma is a vector equation. It says that "the vector on the left is the same as the vector on the right". When are two vectors the same? When their x components are the same and their y components are the same. Whoever authored this problem over-constrained it so that the bottom line is inconsistent with Newton's Second Law.
Addendum to my previous post
This is a bad problem.
Hi kuruman
So it should be :
[tex]m=\frac{F_x}{a_x}=\frac{F_y}{a_y}=\frac{|F|}{|a|}\; ?[/tex]
Another question :
Maybe it is also possible to have acceleration that is constant in x-direction and changing in y-direction? If so, the force will also constant in x-direction and changing in y-direction?
Thx
songoku said:
Hi kuruman
So it should be :
Another question :
Thx
You are correct on both accounts. But the ratio
Fx/ax should be equal to to Fy/ay and equal to |F|/|a| at all times, no matter what the time dependence of the individual components is.
Stated differently:
The angle between the acceleration vector and the x-axis is
arctan(20/(6/5))=33.7o
The angle between the force vector and the x-axis is at all times
arctan(1/3) = 18.4o
Conclusion: The acceleration vector does not point in the same direction as the force. What does one make of this?
If the given force is the only one acting on the mass, then it is a bad problem because F is the net force and must be in the same direction as a. If F is not the net force and there is another force that tips the acceleration vector relative to the given force, the problem mentions no such force or asks you to find it. Still bad problem.
Hi kuruman
After reading your explanation, I agree that this is bad problem
Thx a lot for your help ^^
