Solving Motion of a Particle: Types of Motion & Equation
  • Thread starter Thread starter Gwilim
    Motion Particle
The problem involves a particle of constant mass moving one dimensionally under the influence of a restoring force proportional to its displacement from the origin and a damping force proportional to its velocity. Participants are tasked with writing an appropriate equation of motion and describing the three possible types of motion associated with the system.
  • Participants discuss the formulation of the equation of motion, with attempts to express it in terms of constants related to the forces acting on the particle. There is also exploration of the types of motion, with some suggesting phases of motion rather than distinct types. Questions arise regarding the nature of the restoring force and the implications of different damping scenarios.
The discussion is ongoing, with participants providing insights into the formulation of the equation and the types of solutions to the differential equation. Some guidance has been offered regarding the interpretation of damping types, but there is no explicit consensus on the definitions or classifications of motion types yet.
Participants are navigating the definitions of restoring and damping forces, as well as the implications of different constants in the equation of motion. There is mention of needing to clarify the relationship between the solutions of the differential equation and the physical types of damping.
Gwilim
A particle of constant mass moves one dimensionally under the influence of a restoring force, proportional to the displacement from the origin, and a damping (resistive) force propportional to the velocity. Write down an appropriate equation of motion for the particle. escribe the three possible types of motion for this problem, describing the solution in each case.
2. The attempt at a solution
the equation of motion:
F = R - D
F is the resultant force, R is the restoring force, D is the damping force.
There are three constants in the problem: the mass of the particle and the constants of proportionality of the two forces. Calling them c1, c2 and c3:
c1x'' = c3x - c2x'
c1x'' + c2x' - c3x = 0
The three types of motion, at a guess, would be net acceleration, constant velcoity and net deceleration, but I have no good reason for suppoising this to be the case.
How do I complete the question?
Do you have a problem in your textbook that deals with a mass attached to a spring on a horizontal table? hint restoring force...
Now do you have a problem that deals with friction as a function of velocity? hint maybe air resistance on the mass with the spring attached as stated above?
c1x'' = c3x - c2x'
First, the restoring force should be [itex]-c_1 x[/itex], so as to always accelerate the mass back towards the origin. Second, you really only need two constants, just divide your entire equation by the mass...[itex]\frac{c_2}{c_1}[/itex] and [itex]\frac{c_3}{c_1}[/itex] are just different constants, so you can write
[tex]x''+\alpha x' + \beta x=0[/tex]
where [itex]\alpha[/itex] and [itex]\beta[/itex] are positive.
I would say that positive acceleration, zero acceleration and negative acceleration are 3 different phases of the mass' motion, not 3 different types of motion.
Instead, try solving the above ODE...you should find that there are 3 types of solutions depending on whether [itex]\alpha^2-4\beta[/itex] is equal to zero, less than zero or greater than zero. Physically these 3 solutions correspond to different types of damping...do you know what 3 types of damping these solutions correspond to?
gabbagabbahey said:
First, the restoring force should be [itex]-c_1 x[/itex], so as to always accelerate the mass back towards the origin./
Thanks, I didn't knwo what a restoring force was, I assumed it meant that it restored the motion of the particle or some such nonsense.
Good, thanks.
Yeah I thought my answer there was useless.
IIRC the three forms solutions to a second order ODE take are:
Ae^ax + Be^bx
Ae^ax + xBe^bx
Ke^kx(sin(ax)+cos(bx))
A B K a b k all being constants.
So I assume those are the three types of motion.
I don't, no
Ae^ax + Be^bx
Ae^ax + xBe^bx
That's more or less correct, but you will have an easier time comparing these 3 types, by writing 'a' and 'b' in terms of [itex]\alpha[/itex] and [itex]\beta[/itex]...pay special attention to the sign of the exponents in each case...which solutions decay the fastest?
Afterwards, look up the terms 'critical damping', 'underdamped' and 'overdamped' :wink:
  • · Replies 0 ·
