Intro Physics problem - 2 oncoming trains, help
The problem involves two trains traveling towards each other from Chicago and Atlanta, with given speeds and a distance of 900 km between the cities. Participants are exploring the application of constant acceleration equations to determine when the trains will meet.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the use of constant acceleration equations and question how to apply them given that the trains are moving at constant speeds. There is confusion regarding the acceleration values and the correct interpretation of the equations.
Some participants have identified that the acceleration is zero, which simplifies the equations. There is ongoing exploration of how to set up the equations for both trains to find the meeting point, with no consensus yet on the final approach.
Participants are working with the conversion of distance from kilometers to meters and are uncertain about the units of time. There is a recognition of the need for a common reference point for both trains in the equations.
matxjos
Hey I'm in high school and I need help with this seemingly easy problem.
I have 3 constant acceleration equations but I don't know how to use them in conjunction with this problem.
A train leaves from Chicago toward Atl going 20 m/s. At the same time another train leaves from Atl going to Chicago at 25 m/s. The cities are 900km apart
When do the trains meet?
How long before they meet?
What are the equations that you have? What do they describe? What kind of strategy do you think is appropriate? Give us your thoughts and we will help you.
ok i have
x = x(starting distance) + v(starting vel.)t +.5at^2
v^2 = v(starting)^2 +2a(x-x[starting])
and v=v(Starting) +at
i found the amount of time is 300 for the 20m/s train and 268.3281573 for the 25 m/s train.
but how to found the time they meet?
Just a moment. What did you use for the acceleration a? Also, when you say you "found the time", how did you find that time? What is that time?
ah shoot you made me realize i used velocity for the acceleration dang it.
and yeah, i have no idea what time is supposed to be in. I'm guessing seconds.
and also one has to change the 900 km to 900000 metres I'm pretty sure.
i sort of have no clue on this problem...
So what is the value of the acceleration and what happens when you plug that value in your equations?
Yes, you do have constant acceleration in this problem, but it is zero. In this problem, the acceleration terms drops out. The velocities are constant.
This equation, x = x(starting distance) + v(starting vel.)t +.5at^2 becomes
x = x0 + vt
ummm so i used the v^2 = v(starting)^2 +2a(x-x[starting])
i got .222 = acceleration for the 20 m/s train
and .34722222 for the 25 m/s train...
now what?
phrak how did you know the acceleration terms dropped out?
i used your equation though and i got
t=45 - 20 m/s tain
and
t=36 - 25 m/s train
but i left the distance 900 in km.
Going back to post#6, what is the acceleration (phrak already told you) and what happens to your equations when you put that value in?
oh ok i see now that the acceleration is 0...but how does this help me figure out when the trains meet and how long before the do?
It helps you if you underdtand what you've got. The equation that you get for zero acceleration
x = x0 + vt
gives you the position of a train at any time t, where x0 is the position with respect to a reference point when the train begins to move and v is its velocity. Note that this reference cannot be one point for one of the trains and another point for the other train. It must be the same for both trains. So let's say you choose Chicago as the reference point. Can you rewrite the above equation twice to get two equations expressing the position (from Chicago) of each train at any time t? This is step 1. Complete this and we will move to step 2.
10K
9K
