How much electricity is generated from a 1.8 degree step induction motor?
A 1.8-degree step induction motor can generate approximately 6 volts at a couple of hundred milliamps when cranked manually. This was demonstrated in a practical application where a stepper motor was used to power six 6-volt lamps for a science fair project. The setup included a custom wooden base with switches, allowing users to experience varying torque by lighting different lamps. This information is valuable for understanding the output capabilities of stepper motors in DIY projects.
  • Understanding of stepper motor mechanics
  • Basic knowledge of electrical circuits
  • Familiarity with voltage and current measurements
  • Experience with DIY electronics projects
  • Research the specifications and performance of various stepper motors
  • Learn about electrical load calculations for DIY projects
  • Explore methods for measuring voltage and current output from motors
  • Investigate torque characteristics of stepper motors under different loads
This discussion is beneficial for hobbyists, educators, and DIY enthusiasts interested in practical applications of stepper motors, particularly in generating electricity for small projects.
jeff1233219
I found a step induction motor in a printer and I want to find out how electricity it puts out and at what speed it is spun.
About 18 years ago, a kid and his grandfather walked into the shop I worked at. They were looking for a generator for a science fair project, and by that time they were as rare as hen's teeth.
SO, I hooked him up with a stepper motor, cut him a 4" shaft for it, and fitted the shaft with a knob. We did all this for gratis, and sent him over to a shop that sold electrical parts. They set him up with about 6, 6v lamps, which he could supply by cranking the stepper.
They stopped by my shop once more and the kid's granddad had made a wooden base with switches and a lexan image of Texas. It was quite the rig. Just by cranking the handle, they could light up various "cities," and experience the increased torque associated with lighting more lamps.
So, given that you have a similar motor and shaft, you could probably crank out 6 volts at a couple of hundred ma.
Mike
  • · Replies 33 ·
