Concentration of photons in a beam of light
The discussion revolves around the concentration of photons in a beam of light, particularly in the context of laser beams. Participants explore whether the number of photons can be calculated based on beam properties such as distance and cross-sectional area, and delve into the implications of photon behavior and measurement techniques.
  • Some participants propose calculating the number of photons in a beam of light using the relationship E=nhf, where E is energy, n is the number of photons, and hf is the energy per photon.
  • Others express confusion regarding the concept of photons being "end-to-end" in a beam, comparing it to the behavior of liquids and gases.
  • One participant suggests measuring beam power with a photodiode to determine the energy striking a surface, which could help estimate the number of photons per unit time.
  • Another participant introduces the complexity that photon number is non-conserved and discusses the implications of this on measurements and efficiency of photodetectors.
  • Some participants question the meaningfulness of describing photons as having spatial size and suggest looking for related discussions in the quantum physics forum.
  • A later reply raises a question about whether there is a maximum number of photons per unit distance at a given intensity and cross-section size, leading to a discussion about the maximum intensity of a laser beam.
  • Participants discuss the limitations of photodiodes and the concept of quantum efficiency in measuring photon numbers.
Participants express varying degrees of understanding and agreement on the concepts discussed. There is no clear consensus on the implications of photon behavior, measurement techniques, or the maximum intensity of laser beams, indicating multiple competing views remain.
Limitations include assumptions about the efficiency of photodetectors, the non-conservation of photon number, and the complexities of measuring photon concentration accurately.
taylaron
Hi, I've been pondering over the properties of a beam of light and I'm curious if the concentration of photons in eg. a laser beam can be calculated.
To elaborate on this question, let me ask if we can calculate the number of photons in a beam of light x distance long with a given cross section size.
when I think of a beam of light, I get the notion that the photons that make up the beam are not end-to-end. or are they? when I say end-top-end I refer to the similarities of a liquid compared to a gas.
-I'll stop here for now.
Regards-
Tay
Science news on Phys.org
You can do that by determining the energy of the beam
E=nhf
where n is the number of photons
Hi there,
I don't really get your end-to-end comment.
Cheers
Regards-
Tay
1. Assuming that you have a ~monochromatic source, take a photodiode, and measure the beam power. This will tell you the energy per unit time that is striking the photodiode over that cross section (assuming you have the full cross section striking the photodiode).
2. You know that E=hf, i.e. the energy per photon, for that particular frequency.
3. It should be straightforward to find # of photon striking the surface per unit time within that cross section.
Zz.
And *x/c
Andy Resnick said:
Actually, it's not so simple- photon number is non-conserved, and the photon number and field amplitude are noncommuting variables. For an interesting discussion, see:
http://math.ucr.edu/home/baez/photon/
But one can also argue that no photodiode is 100% efficient.
Still, that is what we use to quantify the quantum efficiency of photocathodes/photodectectors, etc.
Zz.
fatra2 said:
Hi there,
Cheers
the end-to-end comment refers to how particles can be touching one another or how they can be separated by space. similar to a liquid compared to a gas.
Now that we've established that it is possible (within some accuracy) to count the number of energetic photons per unit time, length, cross section size and intensity I am going to evolve my question into some thing more complex.
Is there a maximum number of photons per unit distance at a given intensity and cross section size? let me rephrase: "is there a maximum intensity of a laser?"
-im thinking about photons in a physical sense (although probably incorrect) being back-to-back. Possibly defining the maximum intensity of a laser beam.
any thoughts?
Regards,
-Tay
I don't think it is meaningful to describe a photon as having a spatial size in the sense that you want to use it here. Try searching the quantum physics forum here for threads about "photon size." I know it's been discussed there several times in the past.
Zz.
I don't understand what you mean.
1. "But one can also argue that no photodiode is 100% efficient."
By using a photodiode to measure the power of the light source, I'm assuming that the photodiode is 100% efficient. There is no such thing. So one doesn't have to go to the extent of arguing the photon number isn't conserved. The instrumentation itself already has a higher degree of error than worrying about photon number conservation.
2. "Still, that is what we use to quantify the quantum efficiency of photocathodes/photodectectors, etc."
Photodiodes, photodetector, photocathodes, etc.. all have what is known as a quantum efficiency. How many electrons comes out for the number of incoming photons. This is a common number. Hammamatsu uses this in their specs, for example. So obviously, even with the fact that we don't have anything that has 100% QE, such technique of measuring # of photons and determining its QE is still quite valid and useful.
Zz.
I guess I didn't understand why you said those sentences in response to my comment where I summarize the "photons, schmotons" thread...
I don't see how detection and detectors relate to the statement "photon number and field amplitude are noncommuting variables".
  • · Replies 24 ·
  • · Replies 22 ·
  • · Replies 26 ·
  • · Replies 21 ·
