Protein pH titration (Henderson-Hasselbalch)
The discussion revolves around a homework problem involving the pH titration of histidine with NaOH, focusing on the application of the Henderson-Hasselbalch equation and the implications of protonation states of the amino acid. Participants explore the stoichiometry of the titration and the resulting pH changes based on the addition of a strong base.
  • Homework-related
  • One participant attempts to apply the Henderson-Hasselbalch equation but questions the validity of their result, suggesting that the pH will be greater than 6.0 due to the addition of NaOH.
  • Another participant expresses uncertainty about the initial conditions, arguing that stating all acid-base groups are protonated is not a quantitative statement and raises concerns about the equilibrium position at different pH levels.
  • A third participant outlines a stepwise approach to pH changes with incremental additions of NaOH, referencing specific pKa values for histidine but expresses confusion about the increments of alkali used.
  • One participant suggests treating histidine as a triprotic acid similar to phosphoric acid, indicating that the approach to solving the problem should be analogous, despite differing pKa values.
  • Another participant critiques the wording of the question, questioning whether it is accurate to describe phosphoric acid in solution as fully protonated, highlighting the complexity of protonation states in weak acids.
Participants express differing views on the interpretation of the problem and the implications of protonation states. There is no consensus on how to approach the solution or the validity of the initial conditions presented in the question.
Participants note limitations in the problem's wording and assumptions regarding protonation states, as well as the need for clarity in defining the equilibrium conditions at various pH levels.
physicsstudent14
A solution of histidine has all acid-base groups protonated. The pKa of the carboxy group is 1.8, the amino group is 9.2, and the side chain is 6.0. For each mole of amino acid, 2.5 moles of NaOH are added. What is the pH of the solution?
Henderson-Hasselbalch equation: pH = pKa + log ([A-]/[HA])
I am trying to answer this question for a practice exam. I know that the base will deprotonate the protein, starting from the carboxy group followed by the side chain. I assume that the NaOH is very basic, so it will definitely cause a pH of greater than 6.0. How do I proceed from there?
My attempt: pH = unknown
pKa = 1.8, 6.0, 9.2
[A-]/[HA] = 2.5
pH = 9.2 + log(2.5) = 9.59, but this is wrong.
Could someone please help me with this problem. Thank you very much.
Honestly - no idea how to solve the question. The most obvious approach will be to calculate initial pH and continue from there, just calculating stoichiometry and NaOH excess. However...
This is not a quantitative statement. All groups are protonated - no matter wht pH is, it is just a matter of where the equilibrium lies. At pH 10 there is one caroboxylic group protonated for every 108 molecules, at pH 0.8 there is one NOT protonated carboxylic group for evey nine protonated.
Could be they want us to assume molecule like H3Histidine3+ that reacts with excess base. That's wrong, as such protonated molecule will exist only in the presence of huge excess of strong acid, which can't be ignored when calculating final concentration of the base.
So - either I have not yet waken up, or the question has no solution as worded.
According to my professor, adding alkali neutralizes protons so that...
Adding 0.5 mol of alkali will give a pH of the carboxyl group pKa = 1.8
Adding 1.0 mol of alkali will give a pH between 1.8 and 6.0
Adding 1.5 mol of alkali will give a pH of the histidine group side chain pKa = 6.0
Adding 2.0 mol of alkali will give a pH between 6.0 and 9.2
Adding 2.5 mol of alkali will give a pH of the amino group pKa = 9.2
Adding 3 mol of alkali will fully deprotonate the histidine.
I'm confused as to how he go the 0.5 mol increments of alkali.
Take a look at the Henderson-Hasselbalch equation - at pH=pKa acid is exactly 50% neutralized ([HA]=[A-]).
Trick is - while he is right about neutralization stoichiometry, he still has no idea what the final pH is.
Treat the hisitidine exactly as you would treat a phosphoric acid buffer problem (H3PO4). Histidine can be though of as a triprotic acid in this example.
Have you done any problems using phosphoric acid in a like manner? For example, what would the pH be for a phosphoric acid solution that has had 2.5 equivalents of NaOH added? The pKa's are different but not the approach.
Borek, I know you know how to do this problem!
What I don't like about the question, is the wording.
Would you say that phosphoric acid in its solution is fully protonated? 0.1M solution has pH around 1.6 - that means around 25% is in the form of H2PO4-. Perhaps that's nitpicking, but I still don't like it.
