Effect of electric field on a dielectric
The discussion revolves around the effect of an electric field on a dielectric medium, particularly focusing on how external fields influence the polarization of non-conducting materials.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the behavior of atoms in an electric field, discussing dipole formation and the resultant effects on the dielectric medium. There are questions regarding the correct representation of the total electric field in relation to the external and induced fields.
The conversation includes detailed explanations of the polarization process and the resulting electric fields. Participants are actively engaging with each other's interpretations, particularly regarding the mathematical representation of the fields involved.
Some participants question the assumptions about vector addition in the context of electric fields, indicating a need for clarity on the signs and directions of the vectors involved.
Rajat jaiswal
friends,
can anyone explain me the effect of electric field on a dielectric(non- conducting) medium
First, let's have a look at the effect an external field creates on an otherwise spherical atom. When the atom is placed in the external field, the positive charges tend to move along the direction of the field while negative electron gas cloud in the opposite direction. If the field is strong enough it will break the atom with the electrons ripped off. (That is ionization). But if the field is not too large, there is an effective separation of positive and negative charges on the atom which leads to the formation of a dipole. For small fields, it is found that the induced dipole [tex]\vec{p}=\alpha \vec{E}[/tex], where [tex]\alpha[/tex] is the atomic polarizability.
Coming to a dielectric, when it is placed in an external field little dipoles are created which essentially point in the same direction. So if we consider a homogeneous dielectric, the positive charge of one dipole coincides with the negative one of the next one and effectively cancels it. This leads to the cancellation of all the charges within the bulk leaving out charges sticking on a very thin layer on the surface. The surface whose (outward) normal is opposite the field gets a negative charge while that one having the normal in the direction of the field gets a positive charge. These charge then create a field of their own which runs in the direction opposite that of the external field. The total field is the sum of the two fields: [tex]\vec{E}_\mathrm{tot}=\vec{E}_\mathrm{ext}+\vec{E}_\mathrm{d}[/tex]. Since the two fields are opposite inside the dielectric, the resultant field is less inside the dielectric.
However, these are the consequences. The answer to your question should be: An electric field polarizes a dielectric.
...you mean:
[tex]\vec{E}_\mathrm{tot}=\vec{E}_\mathrm{ext}-\vec{E}_\mathrm{d}[/tex]
no drizzle. you add them vectorically. the effect will be to subtract their magnitude since the two vectors are pointing in opposite directions.
I’m quite convenient with the sign of the vector been represented in the equation [it symbolizes a direction], it also could be written this way;
[tex]\vec{E}_\mathrm{tot}=\vec{E}_\mathrm{ext}+(-\vec{E}_\mathrm{d})[/tex]
  • · Replies 37 ·
13K
