Gain-Bandwidth product question
  • Thread starter Thread starter bitrex
    Product
The Gain-Bandwidth Product (GBWP) of an operational amplifier (op-amp) with a bandwidth of 1 MHz and a gain of 10 results in a unity gain frequency of 100 kHz. To determine the effective cutoff frequency where the gain is down -3 dB, it is essential to consider the influence of other poles in the system. If these additional poles are positioned above 100 kHz, the -3 dB frequency can be approximated to 100 kHz, confirming the relationship between gain and bandwidth in op-amp configurations.
  • Understanding of Gain-Bandwidth Product (GBWP)
  • Familiarity with operational amplifier (op-amp) configurations
  • Knowledge of frequency response and -3 dB cutoff
  • Basic concepts of pole-zero analysis in control systems
  • Research the calculation of -3 dB cutoff frequency in op-amps
  • Study the effects of multiple poles on frequency response
  • Explore operational amplifier stability and compensation techniques
  • Learn about the implications of GBWP in circuit design
Electrical engineers, circuit designers, and students studying analog electronics who are interested in understanding the frequency response of operational amplifiers and their applications in circuit design.
bitrex
If I have an op-amp with say, a hypothetical bandwidth of 1 MHz, and I use it in a configuration where I have a gain of 10, I know that I will only have unity gain at an input frequency of 100kHz. What I am wondering is how I go about calculating what the effective cutoff frequency is, i.e. where the gain is down -3dB? Thanks!
bitrex said:
.. and I use it in a configuration where I have a gain of 10, I know that I will only have unity gain at an input frequency of 100kHz. ...
No that's incorrect. So long as the other poles (apart from the dominant pole that sets the 1MHz GBWP) are above 100kHz then 100Khz will indeed be a very good approximation to the actual -3dB frequency.
  • · Replies 47 ·
