A thought experiment doubt on General Relativity.
The discussion revolves around the relationship between the Equivalence Principle and General Relativity, particularly focusing on the behavior of light in gravitational fields and free-falling frames. Participants explore thought experiments to illustrate their doubts and understanding of these concepts.
  • One participant expresses confusion about the Equivalence Principle and its implications for light, questioning how light is affected by gravity based on this principle.
  • Another participant explains that in a free-falling box, light behaves as if at rest, hitting the expected spot, and discusses how light's behavior can be understood in terms of an external observer's perspective.
  • A third participant introduces the weak equivalence principle, explaining that different masses fall at the same rate and how this relates to the perception of light in a gravitational field.
  • Some participants raise questions about whether light's velocity changes in a gravitational field and how this aligns with the principles of special relativity.
  • There is a mention of the proper acceleration of the free-falling box being zero, contrasting it with the upward acceleration of the Earth's surface.
Participants do not reach a consensus, as there are multiple competing views regarding the implications of the Equivalence Principle on light and the nature of gravitational effects in different frames of reference.
Participants highlight various assumptions, such as the effects of tidal forces in a gravitational field and the implications of different reference frames on the behavior of light. The discussion remains open-ended with unresolved questions about the relationship between acceleration and the behavior of light.
yash25
I was reading a chapter on "General Relativity" a few days ago. (I was reading Arthur Beiser: Modern Physics)I found it very hard to digest the relation between the "Equivalence Priciple" and "The General Theory of relativity".The equivalence relation states that "An observer in a uniformly accelerating frame cannot distiguish between the effect of the accelaration and the effect of a gravitational field". This principle follows from the fact that the gravitational and inertial masses of a body are equal( proportional). What do we mean by these two masses? Further , Beiser states that , from the above Equivalence principle, we can state that, light too, is affected by gravity. How could he come to this conclusion?
Further , I also have developed a mind experiment to support and shape my doubts.
" Imagine a box(made of glass, so that anyone on Earth can view the contents of this box) plummeting towards the earth(free falling).
Now , imagine a laser torch flashing a laser beam from one wall of the box to the opposite one (horizontally).
1)Will this light hit the opposite wall at exactly the same height as when it is emitted from the torch? By this , I mean that will all the bodies in the "frame of the box" be affected by the constant accelaration(including the light) towards the earth? (But according to the special theory , this property belongs only to the frames traveling with a constant velocity. Does this theory even stretch to the frames traveling with a constant accelaration?)
Further, a person watching this phenomenon from the surface of the Earth will see the beam of light bending downwards,and thus light will be affected by gravity in his frame of reference.
2)Now, let us assume the laser torch to be fitted on the ceiling of the box, so that the beam travels from the ceiling to the floor. In this case the beam will travel vertically downwards and will be accelarated by gravity. Does this mean that the light will be accelarated and it's velocity will increase? This sounds absured, since the special relativity itself states that nothing can travel faster than light. "
I hope these doubts aren't really trivial ...I'm really new to this branch of physics...
If you shine a light within a box in free-fall in a gravitational field, then apart from tidal effects (due to the non-uniformity of the field and the non-zero size of the box) it behaves as "at rest" and hits the expected spot. It is this effect which means that light must be affected by gravity as well.
From the point of view of an external observer using an isotropic background coordinate system (or similar), the reference frame of the falling observer is curved slightly from one side to the other, with the box sides being non-parallel, the top and bottom curved and the bottom being slightly smaller than the top. Relative to the isotropic background coordinate system, the speed of light appears to decrease as twice the relative potential.
When the light beam travels horizontally, its acceleration is twice the Newtonian acceleration, the sum of the acceleration caused by the curvature of the box plus the acceleration of the box itself. When it travels vertically, it's actually slowing down relative to the coordinate system.
However, if instead of the velocity we consider the value of v/c2 or of the momentum Ev/c2 the picture is simpler, in that the rate of change of this is simply (1+v2/c2) times the Newtonian value of the same quantity, regardless of whether it's horizontal, vertical or any other direction. The "1" term is just like Newtonian gravity, and the "v2/c2" term is the part which is due to the distortion of rulers (being curved in the horizontal direction and shrunk at lower potentials).
The weak equivalence principle is the observation that is that if you drop two different masses from a height, they will both hit the ground at the same time (assuming the two masses are much smaller than the mass of the earth).
In Newtonian physics, Coulomb's law is m1.a1 ~ (p1.p2)/(r.r). Across all particles, there is no relation between an inertial mass m1 and its electric charge p1.
The law of gravity has the same form as Coulomb's law m1.a1 ~ q1.q2/(r.r) - the big difference is that across all particles inertial mass m1 is proportional to gravitational charge q1. Instead of calling q1 "gravitational charge", we call it "gravitational mass". Because of the proportionality, across all different particles, a1 ~ q2/(r.r) - the acceleration depends only on the mass of the earth, and all masses hit the ground at the same time. So in Newtonian physics, the equivalence principle is modeled as inertial mass being proportional to gravitational mass.
Since all masses fall at the same rate, if you stand on a freely falling mass, other freely falling masses will appear stationary to you - ie. the gravitational field disappears. But if you stand on a freely falling mass, and light appears to bend, then you will be able to deduce that the gravitational field has not disappeared. So if we guess that there is a strong form of the equivalence principle that when you stand on a freely falling mass your observations of other freely falling masses *and* freely falling light will appear as if there is no gravitational field - then you will predict that light will appear to go straight for an observer on a freely falling mass, and by consistency, you will also guess that light will appear to bend to an observer who is in a gravitational field, but who is not freely falling.
It seems you have this backwards. The freefalling box has zero proper acceleration. The Earth's surface is accelerating upward (in GR). It is a box at rest with Earth's surface that is equivalent to an accelerating box in deep space, assuming each is accelerating at 1 G (9.8m/s^2). A freefalling box is equivalent to an unaccelerated box in deep space. (all assuming an uniform gravitational field).
The equivalence principle never equates a freefalling box with an accelerated box.
  • · Replies 26 ·
  • · Replies 29 ·
  • · Replies 28 ·
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 221 ·
18K
  • · Replies 17 ·
  • · Replies 36 ·
