Question Concerning Gauss' Law
  • Context: Graduate
  • Thread starter Thread starter jslam
    Gauss Gauss' law Law
The discussion revolves around the interpretation and application of Gauss' law, particularly in relation to the electric field changes across a layer of charge. Participants explore the connections between different formulations of Gauss' law as presented in a specific textbook, addressing both theoretical and conceptual aspects.
  • One participant references a textbook that states Gauss' law as relating the flux through a closed surface to the enclosed charge, questioning the connection to the change in electric field across a layer of charge.
  • Another participant seeks clarification on what is meant by "layer," prompting further explanation about layers of charge, including infinite flat sheets and spherical shells.
  • A later reply clarifies that the relationship discussed only applies to the component of the electric fields normal to the surface and explains how to derive the relationship using Gauss' law.
  • It is noted that the general case involves electric flux density rather than just the electric field, particularly in contexts involving bound charges at material interfaces.
  • The concept of boundary conditions in electromagnetism is mentioned as relevant to the discussion.
Participants express differing levels of understanding regarding the relationship between Gauss' law and the electric field changes across charge layers. While some explanations are provided, no consensus is reached on the clarity or implications of these relationships.
There are references to specific cases and conditions under which Gauss' law applies, including the distinction between electric field and electric flux density. The discussion does not resolve the nuances of these concepts or their applications in different scenarios.
jslam
I'm reading the book "Electricity and Magnetism: Vol. II" by Edward M. Purcell, in which he describes Gauss' law as stating that the flux through a closed surface is 4π times the enclosed charge (he uses the Centimeter-Gram-Second system).
Later, he refers to Gauss' law as stating that the change in field from one side of a layer to the other must be 4πσ, where σ is the charge density in the layer.
I don't see the relation. Maybe it's an obvious corollary of Gauss' law, but in any case I don't understand how.
The offending text can be found here:
http://rapidshare.com/files/270469221/offending_passage.pdf
The bad news actually only starts in section 1.14 (on the second page), but the first page is included because it get reffered to in the one of the two offending passage.
What is this "layer" that you are talking about?
Sorry. It's a layer of charge. The cases referred to here are an infinite flat sheet of charge with uniform charge density, a spherical shell of charge with uniform charge density and then finally any old layer of charge, saying in each case that from one side of the layer of charge to the other, there has to be a difference in field of 4πσ. I don't know if you read the attached PDF (or if you weren't able to for some reason, in which case let me know), but it explains it all.
Oh well that's a correct description then, except it only applies to the component of the fields normal to the surface. The net flux over any closed surface is proportional to the amount of charge in the enclosed volume, via Gauss' law. So if I enclose a sheet of charge of charge density \sigma, then the net flux will be proportional to the product of the enclosed area of the charge sheet times \sigma. So, just take the surface integral to the limit case where the thickness of the volume (thickness is normal to the charge sheet) goes to zero. Now, the enclosed "volume" is the charge sheet, the flux is now the area times the difference between the normal electric fields on the opposite sides of the sheets, this is still proportional to the area times \sigma. So the areas cancel out and you are left with the relationship that the difference between components of an electric field normal to a surface on either side of the surface are proportional to the charge density of any bound charges on that surface.
Another note though is that the general case deals with the electric flux density, sometimes called the displacement field, and not the electric field. This case deals with bound charges that collect on the surface between different materials. The case where we are talking strictly about the electric field only applies to a homogeneous medium.
This is one of what are known as the boundary conditions and are discussed in most electromagnetic textbooks.
http://www.amanogawa.com/archive/docs/EM5.pdf
  • · Replies 83 ·
13K
