Calculating Deceleration in a Safety Net Jump
  • Thread starter Thread starter Matt
    Fire Net
The discussion revolves around calculating the deceleration experienced by a jumper who falls from a height of 15 meters into a safety net that stretches 1 meter before bringing the jumper to rest. The problem involves concepts from kinematics and dynamics.
  • Mixed
  • Participants explore the use of kinematic equations to determine deceleration, questioning the values used in calculations and the assumptions made about the final position and time. There are discussions about breaking the problem into two parts: free fall and deceleration upon hitting the net.
Some participants have provided guidance on how to approach the problem by separating it into distinct phases. There is ongoing questioning about the validity of the calculations and the physical reasonableness of the results, particularly regarding the high deceleration values obtained.
Participants express uncertainty about specific values used in calculations, such as initial velocity and time, and question the appropriateness of the assumptions regarding the net's effectiveness and the resulting forces experienced by the jumper.
Matt
A person jumps from a fourth story window 15 m above a safety net. THe jumper stretches the net 1.0 m before coming to rest. What was the deceleration experienced by the jumper?
Equation:
x = x0 + v0t +.5at^2
15 m = 1 m + 8.6 m/s(2s) + .5(a)(1.75s^2)
15m = 1 m + 17.2 m/s^2 + .875s^2(a)
-3.2 m = .875 s^2
-3.66 m/s^2 = Deceleration
Does this look right? I'm not sure about the 1 m as the final position...
Wait, I already see a problem, forgot to square the time...
Equation:
15m = 1 m + 17.2 m/s^2 + 1.53s^2(a)
-3.2 m = 1.53 s^2
2.09 m/s^2 = Deceleration
Does this look right? I'm not sure about the 1 m as the final position...That seems like an awfully slow deceleration for jumping out of a window.
Equation:
-3.2 m = .875 s^2
You've got a few errors, and I'm not sure where you got all of your values.
Where did the 8.6m/s , the 2s, and the 1.75s^2 come from?
You're also making mistakes with the units.
'8.6 m/s * s' does not have units of 'm/s^2', it is 'm'
Your tipoff that you are making mistakes comes in the line where you have -3.2m = .875 s^2
those units don't equal each other, therefore you know you must have made a mistake somewhere.
To do this problem correctly, you need to break it into 2 parts.
First part is the freefall. You know starting and ending positions (15m and 0m above the net), you know starting velocity (0m/s), and you know acceleration (-9.8m/s^2). You use those numbers to solve for the velocity before the guy hits the net.
The second part is the deceleration. You have starting and ending positions (0m and -1m), you know starting velocity (from part I), and you know final velocity (0m/s... he is stopped at the bottom). You use those values to solve for acceleration.
Revised: (I always have trouble seeing problems in two distinct parts)
v^2 = v^20 + 2a(x-x0)
v^2 = 0 m/s + 2(9.80 m/s^s)(15m -0m)
v^2 = 294 m^2/s^s
Squareroot(v^2) = Squareroot(294 m^2/s^2)
v = 17.14 m/s
0 m^2/s^2 = 17.14 m/s + 2a(-1 - 0)
0 m^2/s^2 = 294 m^2/s^s -2a
-294 m^2/s^2 = -2a
a = 147 m/s^2
Thats more than 14 gs! Can that be right? Wouldnt the person be dead?
15 g's.
The net is slowing him down to zero velocity in 1/15th the distance.
Not a very good net - He would probably be hurt, but not neccessarily killed.
15 g's is enough to cause damage, but it won't last for a very long period of time. Aircraft ejector seats pull over 100 g's for a split second.
Is the result reasonable? If you don't have a clear mental picture of meters, convert to feet. This guy is falling from a fourth (probably closer to 5th) story window, and stopping in 3 feet. That's a pretty stiff net.
  • · Replies 16 ·
