Thread Closed
Lagrange equation for mass-spring-damper-pendulum
Share Thread Thread Tools
Aug24-09, 12:52 PM   #1
Can someone kind of give me a step by step as to how you get the equations of motion for this problem?
the answer is this:
Though im not quite sure what b and c are.
i guess for reference here is what it looks like after transforming it some:
Here is the website if you need to do any clarification:
http://www.enm.bris.ac.uk/teaching/p...a9213/msp.html
I have another problem similar to this for homework, i just wnat to see this one layed out before i work on my other. Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Aug24-09, 04:10 PM   #2
[tex]
mv_{x} + MV_{x} = C1
[/tex]
[tex]
\int(-BV_{y})dt + \int(-KY)dt + MV_{y} + mv_{y} = C2
[/tex]
[tex]
v_{x} = V_{x} + lsin(\varphi)\frac{d\varphi}{dt}
[/tex]
[tex]
v_{y} = V_{y} + lcos(\varphi)\frac{d\varphi}{dt}
[/tex]
Aug25-09, 06:26 PM   #3
um, could you clarify a little bit more?
my main problem is understanding the relationship between the pendulum and the first mass, M
Aug26-09, 11:01 AM   #4
uppercase symbols for M, small symbols for m.
B is damping coefficient of damper attached on M and K is spring coefficient.
apply momentum conservation on both x and y direction can get above equatiions.
C1 and C2 are initial conditions.
derivation of second equation will be force-acceleration equation.
Not difficult to understant. just "Ft + MV + mv = a constant" in differential form.
It's a second order system. If you re-arrange them, you can get simillar equations as that on the webpage you provided.
If there's something missing, might be geometry equations.
Good Luck.
Aug26-09, 11:14 AM   #5
thanks i appreciate it. I just started a vibrations course and this problem is similar to what i have in homework. i tried looking tah the lagrange equations to get an idea on an answer so i can go back and do the system again using newtonian equations, though as of last night it has started making me rather frustrated :/ and honestly its the pendulum thats messing me up.
Thread Closed
Tags
harmonics, lagrange, oscillations, spring-mass, vibrations
Thread Tools
Similar Threads for: Lagrange equation for mass-spring-damper-pendulum
Thread Forum Replies
3d mass-spring-damper Classical Physics 7
mass-spring-damper system Advanced Physics Homework 0
spring,damper and mass Classical Physics 1
spring mass and damper Classical Physics 0
Need some help with spring-mass-damper problem.. General Physics 8
