How to design a dolphin propulsion swimsuit?
  • Thread starter Thread starter shonagon53
    Design Propulsion
The discussion revolves around the design of a dolphin propulsion swimsuit, specifically a lightweight aerodynamic "rack" with a dolphin tail powered by an electric tubular linear motor. Participants explore various aspects of the design, including motor power requirements, buoyancy considerations, and alternative propulsion methods.
  • One participant proposes using a tubular linear motor for the dolphin tail, questioning the necessary power to achieve a speed of 30 km/h for an average person in water.
  • Another participant suggests that a simple trolling motor might be more effective than a linear motor, citing concerns about power consumption and battery life.
  • A later reply discusses the biomechanics of dolphin movement and suggests that linear motors may not be suitable due to their precision nature, while also acknowledging the need for raw power.
  • One participant raises the idea of using pneumatic actuators for quick movements and notes that side-to-side motion may be mechanically simpler than up-and-down motion due to gravitational forces.
  • Concerns are expressed about safety, emphasizing the importance of ensuring the design is positively buoyant to prevent users from becoming trapped underwater if power is lost.
  • Another participant discusses the potential for marketing the product with eco-friendly messaging, avoiding combustion engines in favor of battery or fuel cell power.
  • A humorous remark is made regarding the marketing slogan "Feel the dolphin in you," suggesting it may already be trademarked.
Participants express a mix of ideas and suggestions, with no clear consensus on the best approach to the design. There are competing views on propulsion methods and safety considerations, indicating that the discussion remains unresolved.
Participants acknowledge various limitations, including the need for raw power, the challenges of buoyancy, and the mechanical complexities of different motion types. The discussion reflects a range of assumptions about the feasibility and practicality of the proposed design.
shonagon53
I'm not an engineer, but I want to design this all for my self. So I have a few questions, for the bright out there. :-) [excuse me for my bad english, I'm not a native speaker].
I want to design a swimsuit (more a lightweight aerodynamic "rack" which you strap yourself into) which has a dolphin tail attached to it, which is thrusted up and down by an electric tubular linear motor. Only, I'm not sure how powerful the motor should be.
The idea is to have a suit with which you can swim up and down in the water, using your arms to gain initial speed (just crawl), and once you attain sufficient speed you let the tailfin do the rest. (You then keep your arms close to your body or keep them straight ahead of you). You use your arms and the weight of your head to steer (like you would driving a motorbike.)
How much power would you need to have such a horizontal tailfin (not a vertical one like that of sharks) kick up and down and push a person of average weight (say 80kgs - 175 pounds) through the water (say one meter, 3 feet under the surface) at a fun speed (say 30km/h - 20miles/ph)?
I'm at a loss.
Would the strongest tubular linear motor of this company suffice?
http://www.calinear.com/products.htm
Brushless direct drive technology
1180 Lb. Peak Force
180 In/Sec
40G Acceleration
Strokes up to 20 inches
The motor would be powered either by batteries (say good for a ride of up to 15 minutes) or by a fuelcell and hydrogen.
[By the way, how much does a good engineer cost? How much would it cost to have an independent engineer design this kind of toy in its entirety?]
You would be much better off to use a simple trolling motor for a fishboat and a motorcylce battery.
A linear motor with encoder designed for industrial use from a 220V 3-phase powered controller. You may want to check on price (guessing $1000+ each) and you'll exhaust a 60lb car battery in very little time (5-7 minutes) if you'd need to run them at full power.
Sorry to be a buzzkill, but pretty tall challenge for a toy. Neat idea though. :)
Cliff
Thx cliff.
I was just thinking, the biomechanics of a dolphin kick movement is a rather linear one (in reality it works with a kind of a muscular "spring", like that of kangooroos), so I thought I'd look into linear motors. They're very powerful when it comes to accelerating, which is basically what the dolphin kick is about. But indeed, these motors are more for precision work, while this toy needs raw power.
I needed the realism of an engineer, and that's what I get. Thx :-). (I think when an engineer starts with: "you would be much better off with...", then I think I've heard enough, lol).
Anyways, more comments welcome.
If you're not going completely underwater, the hydrogen powered has potential. Maybe you could employ some sort of pneumatic actuator for quick, forceful, intermitant movements.
I think side to side motion would be easier to facilitate because the forces and stresses in either direction would be similar where up and down would differ somewhat (gravity working against the up motion and with the down motion, etc).
Cool idea.
Just a word of warning; do not strap yourself into this thing unless it is positively buoyant! When it runs out of power, you will be trapped and helpless underwater.
Yes, I've thought about that. The rack should be positively or neutrally buoyant. The entire lightweight aluminum rack will be mounted inside a fiberglass case, with a nice shape. It shouldn't be too difficult to have a few airpockets in this "backpack". The backpack ends in this long tailpiece, at the end of which your feet are strapped (and behind that, you have the tailfin).
The advantage of the design is that in water, things weigh less, and you still have your arms free (your feet are strapped but I'll design some system -- like with ski's-- where you can kick your feet loose, something like that.)
Cool idea.
Yep, additional pneumatic thrust would be very interesting.
And indeed, shark motion (side to side) would be easier from a mechanical point of view (more equal load distribution), but if this ever gets off the drawing table, I think a dolphin toy has bigger market potential. :-) (Maybe not, I'm not sure).
Anyway, the most important thing is raw power. I don't want to use a combustion engine, since that's directly polluting (and if I ever want to market this, I will want to use metaphors and lines like "become a dolphin" "feel the dolphin in you" "they're your friends" etc... so I obviously can't use a gasoline engine.)
The thing should be battery powered or have a fuelcell (but I think fuelcells are quite heavy).
Ok, thanks a lot for your remarks :-)
"Feel the dolphin in you"?
I think Ann Summers have already registered that marketing slogan as a trademark...
  • · Replies 18 ·
  • · Replies 23 ·
