Information theory question related to ecology
This discussion focuses on calculating forest fragmentation metrics within a square grid landscape, specifically addressing the implications of redundancy in metric values on information content. The user, Seth, proposes calculating entropy for various configurations of forested and non-forested cells to assess the information encoded in these metrics. The conversation highlights the challenge of evaluating all possible combinations as the grid size increases and explores the potential of using Monte Carlo simulations to estimate entropy. Additionally, the discussion questions whether variance measures might provide a better analysis of metric distributions.
  • Understanding of forest fragmentation metrics
  • Familiarity with entropy in information theory
  • Knowledge of Monte Carlo simulation techniques
  • Basic concepts of variance in statistical analysis
  • Research methods for calculating entropy in discrete variables
  • Explore Monte Carlo simulation applications in ecological modeling
  • Study variance measures and their relevance to metric distributions
  • Investigate literature on information theory applications in ecology
Ecologists, data scientists, and researchers interested in landscape ecology, information theory, and statistical analysis of ecological metrics.
wvguy8258
Hi,
I have a square grid that represents a landscape, each grid cell is forested or non-forested. I am calculating 2 different forest fragmentation metrics. Because there is a finite number of combinations of forest and nonforest cells, there is a finite number of possible values for each metric. It is likely that for one or both metrics, more than one combination of forest/nonforest cells will have the same metric value. It seems any such redundancy decreases the amount of information encoded in a metric. If on a small landscape (few cells), I calculated each pattern metric on all possible landscapes (2^# of cells), I could produce a discrete probability distribution for each metric and calculate entropy for each. Does it make sense to do this and with the result say 'the one with greater entropy contains more information about the landscape'? It seems that if each possible landscape had a unique metric value, then that metric has the maximum amount of information for that size landscape. If a metric always gave the same value, it would have an entropy of zero. If this makes sense, and please be brutal if it doesn't, how could one handle the situation where it is not possible to evaluate each possible combination of forest/nonforest cells (each possible landscape)? This will happen quite quickly as the number of cells increase. Is it possible to estimate entropy for a discrete variable using some math or monte carlo simulation? I've been reading about information theory applications for imaging, but usually they are calculating entropy within a single image based upon gray scale values. Any pertinent literature I'm missing? Also, would it be better to analyze my metric distributions using the usual variance measures instead?
Thanks for reading...Seth
Yuck! You use the word metric like the economists do. (Metrics define metric spaces or at least they are closely related to them)
Maybe you can analyze your metric way you do and it might be interesting to look at the information content as the landscapes go to infinity, but until then to me your metric is a simple map from N to N that is not onto.
There are many ways to make the map loose information...
Sorry about my sloppy use of the word metric. Does your simple mapping of N to N take into account that several landscapes can have the same index value. So, it would be a mapping of N to N - (sum over all index values of (number of time an index value appears minus 1))??
  • · Replies 23 ·
  • · Replies 33 ·
